Thread: Above Ground Pool Winter Cover with Safety Fence
    We are getting ready to close our new above ground 21' pool. It has a safety fence attached to the top of it and a partial deck. I was looking at the Hurricane cover, but I do not think that will work. Any tips for a cover that will work with a safety fence?
    Located in Chicago, IL
    21' Doughboy
    Gas Heater
    DE filter
    Re: Above Ground Pool Winter Cover with Safety Fence
    Bump for morning crowd.
    21' Doughboy
    Gas Heater
    DE filter
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    347
    I just use a regular cover and mine will go between the fence and the top rail. I use clips and the wire. I run the wire under the deck and continue on on the other side. On the deck I tie off thru the grommets to upright posts and use my stair steps as weights. I have not had luck reusing covers so I get a cheap one every year.
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
