Results 1 to 8 of 8
Thread: 1st time closer needing some guidance
    Oct 2015
    Wind Gap, PA
    85
    Well I made it through my first season and did pretty well, no major issues but it was tough learning some stuff about my system because it's not a "normal" setup. Thanks to everyone who helped me out!
    Anyway, it seems like everyone uses the rubber expansion plugs to seal their returns etc. Anyone use the screw in type with the oring? Reason I ask is because I have two suction lines towards the bottom of my pool that are a pain to get out when I open the pool. I have to put my head in the water to reach them, I feel like the screw in type would be easier to get out with a long screw driver.
    This is my plan.
    1. Remove the ladders and railings
    2. Shock the pool and then add Poly 60 when the chlorine level drops to about half the level of shock. I'll let the pool circulate for a few hours after this.
    3. I'm not sure how to blow out all my lines from one pipe so I'm going to disconnect each individual line and blow them out one at a time. I'm not lowering the water level because I have a wall pack with cartridge filters below water level. Plus I have suction lines at the bottom of the pool wall I would have to empty the pool to get to those.
    4. After everything is blown out and plugged, reassemble all the pipes.
    5. Drain the pump and blow it out. Haven't decided if I'm going to bring it indoors or not, I think I'll just leave it outside.
    6. Put the safety cover on. There were two 12 inch long 4x4's in the pool by the steps when I opened the pool. I have no idea why these were in the pool. Any ideas????
    Thanks in advance for any help
    19,400 gallon IG ,vinyl, Hayward 1hp Single Speed, Wall-pak Cartridge Filter, Pool filled from well, TF-100 test kit
    Oct 2015
    Wind Gap, PA
    85
    Re: 1st time closer needing some guidance
    I am going to order this for closing
    https://www.amazon.com/dp/B0030BEI0Y...I224V5E6RBOA3V
    Im also thinking about ordering this and putting some in at closing due to filling the pool over the summer with well water
    https://www.amazon.com/dp/B00HZM8AAS...I2LDBZ7JGOU8ND
    The more I read the more I'm thinking I should just use the rubber plugs and not the screw in type. Maybe I can find a socket that fits the wing nut and use a 2 foot breaker bar to loosen the wing nut at opening next year.
    Im also leaning towards not using any antifreeze in the lines. I would have to let the antifreeze into the pool at opening because of how odd my filtration system is.
    Oct 2015
    Wind Gap, PA
    85
    Anyone????
    Mod Squad pooldv's Avatar
    DFW, TX
    16,877
    I am not a pool closer but here is a handy guide from Pool School, Pool School - Closing an In Ground Pool
    Oct 2015
    Wind Gap, PA
    85
    Thanks I've read that many times.
    Aug 2016
    New Haven CT
    61
    Hi I am in the same position and will doing this in a couple of weeks. I don't know how to seal the main drain if that's possible, although the old owners must have done this every Fall.
    Gary
    New Haven, CT
    16 x 32 x 8 in-ground vinyl , sand filter
    22,000 gallons
    Leslie test kit, TF100 test kit
    Oct 2015
    Wind Gap, PA
    85
    Quote Originally Posted by gtr1999 View Post
    Do a title search for main drain, there is a ton of info on it. I know read a lot about main drains when I researched closing my pool but I didn't retain it as my main drain has been sealed off.
    Aug 2016
    New Haven CT
    61
    Thank you
    Gary
    New Haven, CT
    22,000 gallons
