Results 1 to 11 of 11
Thread: How to safely drain a pool?
    Feb 2014
    Louisiana
    8
    My house and pool flooded on August 12th. This killed my pump of course. Here it is now Sept 17th. The water is black as night and has been sitting now for over a month and counting. I have replaced the pool pump, but since I have a cartridge filter I think I may be best off to drain the pool and refill it instead of trying to filter and chemical it clean.
    The fear of course is that the pool could be damaged by draining it.
    One guy is telling me no worries on the water table. It "should be down by now" plus he says his insurance would cover any damage. He says no need to do anything special, just drain the water out.
    Another guy says he would drill holes in the bottom of the pool as it drains starting at the shallow end and more towards the deep end as it is being drained allowing ground water to enter the pool while it is being drained and that is the way to be certain you won't have a problem. After the pool is drained he would fill the holes. I do wonder though how this will look on my pool floor and how well these "filled" holes would hold up over time.
    Any ideas on these two opinions?
    Is there a surefire way to know I can drain the pool without it being damaged? If so, I would just drain it myself.
    Thanks in advance for all of the great advice.
    Darren
    Darren - South Louisiana
    Installed Feb 2009, 34k gal, IG Gunite, Cartridge Filter
    1.5 HP Hayward 2 speed pump
    SWG, SmartPure Ozone Generator
    Tiger Shark cleaner
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    Re: How to safely drain a pool?
    There is NO way I would drain all of the way! You are in Louisiana! The home of LOTS of water!
    I would NOT punch holes in the bottom of your pool........ugly. How will they ever match the old plaster?
    IF you want to drain down some you can. Make sure to leave one foot of water in the shallow end. You can rent a pump to drain it or you can get a cheap one at Harbor Freight.
    Before you drain stock up on chlorine/bleach (same stuff just different %). Have at least 20 gals to start.
    Do you have a test kit? If so please add it to your siggy. If not look in my siggy for the one I think is the best bang for the buck. With you clearing a pool you should also get the XL so you will have enough regents to do the SLAM.
    We are here and ready to help you no matter what you end up doing.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    If I were you, I would call the county agriculture extension. Those guys have much better info on local water tables than anyone does.
    I've seen quite a few videos on YouTube about drilling holes in plaster pools because of hydrostatic pressure. If done with a core drill and careful attention to repair, its not ugly, but it doesnt exactly match.
    If you decide not to drain, then replacing 1/2 the volume at a time - 2 or 3 times could help get you to a place where doing a slam might not be all that bad.
    It might cost a bit of money for the water bill (probably the equivelent of 2 or 3 complete refills), but that might be better than than any other alternatives offered.
    Divin Dave,
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    I don't think Home Owners insurance would pay if you floated the pool. Just an FYI.
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    352
    Do you know whether you already have a hydrostatic valve under the main drain cover to allow ground water to equalize?
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Feb 2014
    Louisiana
    8
    I believe that I do have hydro static valves in the bottom of the pool. I believe this only because there are 3 drain covers down there. I presume only one is the actual drain and the other 2 are hydro valves? However, many people say that they can fail to open if they have never been opened before. The pool is about 8 - 9 years old.
    Tiger Shark cleaner
    Feb 2014
    Louisiana
    8
    True. I am sure homeowners would not pay. The contractor who said his insurance would cover if it floated was talking about his business liability insurance.
    Tiger Shark cleaner
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,734
    I wouldn't rely on liability insurance covering damage to the pool. My policy is already insanely high and I can't imagine what verbiage like that would add to the premium.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    It is likely that two of the covers are for the main drain and the other is for a hydrostatic valve. Dive down and remove the covers to see what is under the covers.
    Dec 2012
    Manassas Park, VA
    205
    how deep is your deep end? When I drained my pool I could not find anyone that had any knowledge on the water table. I bought a post digger from Home Depot and dug down to the depth of my deep end, which is 5' 6". Lucky for me I have a small retaining wall which is about a 1' 6" high so I actually only had to dig about 4'. I let the hole sit overnight to see if it would fill up with any water. The next day it was still dry so I drained to the street and monitored the hole just to be sure. If you do drain, do no drain it to your yard.
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    DFW, TX
    24,450
