Thread: Motor or Pump not working?
    May 2015
    So Cal
    32
    So after this discussion. Looking to replace Pool Pump, Need Advice.
    I decided to just reduce the number of hours the pool filtered to 2.5 hours per day instead of buying a new pump.
    But this recently happened last week.
    https://vid.me/6tFR
    Any idea what is going on here? Seems like the pump isn't turning on. But how do I know which is actually not working?
    23,000 Gallons Plaster Pool & Spa. Southern California
    May 2015
    So Cal
    32
    Re: Motor or Pump not working?
    Nevermind, the pump didn't have any water in it. Problem fixed.
    mas985's Avatar
    Pleasanton, CA
    10,054
    Glad you got it working but there appears to be water under the pump. That is usually a sign of a leaking seal. Check to make sure your pump isn't leaking any water while running.
    Mark
    Hydraulics 101; Pump Ed 101; Pump and Pool Spreadsheets; Pump Run Time Study; DIY Acid Dosing; DIY Cover Roller
    18'x36' 20k plaster, 1/2 HP 2sp pump, Aqualogic PS8 SWCG, 420 sq-ft Cartridge, Solar, 6 jet spa, 1 HP jet pump, 400k BTU NG Heater
    May 2015
    So Cal
    32
    I've check the pump everyday since, i don't see any leaks. I think it's just like moist soil or something. Cause it's all around that area. But ill keep an eye on it.
