Thread: New Pool Owner and new to TFP!
    Sep 2016
    Dallas, Texas
    188
    Hello all!
    I live in the Dallas area with a beautiful wife and triplet 10 year old boys!
    Owner to a newly built 32x20 16,500 GUNITE pool and spa as of about a month ago. Pool ownership has its issues. Right out of the box, I'm dealing with efflorescence buildup on the pool time under my Lueders Limestone retaining wall! Also seeing a hazing film on the tile around the rest of the pool above the water line. Suggestions for "easy" removal and maintenance?
    Thanks for having me!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    29,289
    Re: New Pool Owner and new to TFP!
    HI! You sure do have your hands full with the Trips alone throw the pool not going as smooth as it could into the mix equals not fun times
    How about starting a thread in the "just getting started" section so we can work on your issues. When you get over there make sure to include pictures of your problem areas.
    I will tell you that you will be asked how you have been testing your water and how are you adding chlorine to it. Here is a link to THE corner stone for TFP:
    I will be on the look out for you over there!
    Sep 2016
    Dallas, Texas
    188
    Will do! Thanks!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,201
    Welcome to TFP, congrats on the new pool!
    2 or 3 to 1 diluted muriatic acid and a brush will clean up the efflorescence and the haze. Always add acid to water and never water to acid. You can use up to full strength for tougher areas.
    Sep 2016
    Dallas, Texas
    188
    Thanks pooldv! Worked like a charm!
    Matt- IG gunite pool and spa built Summer 2016: 32' x 20' overall with two 4' x 8' tanning ledges. 6'x6' attached spa with spillover. Depth 3' to 5' to 4'. 16.4K gal. Lueders Limestone retaining wall and coping. Equip: Pentair SVRS vari. speed pump. Pentair 60 sq. ft. DE filter. Pentair Kreepy Crawly Plat. cleaner. Pentair MasterTemp 400,000 BTU NG heater. 1.5 HP spa air blower. Nature2 Sanitizer. Taylor K-206C. My 2016 Build
