Thread: just got my test kit
    May 2009
    Trenton NJ
    497
    I did something alittle foolish,I was so eager to use the tst kit I went right to it and performed the tests(after reading all lit.) and everything was good except my CH, it was 170 and needs to be 250ppm (fiberglass pool).
    Well after I did the test I forgot I needed to vac. pool then backwash. Do you think it will change my numbers drastically? My cya was 80 just where I needed it. Should I perform all tests again?
    Also I put in some cal. elevator (after backwash duh) how long before can I test for CH.
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    May 2009
    Trenton NJ
    497
    Re: just got my test kit
    One more thing my fc 7.5
    cc 1
    How do I get cc to zero?
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    are you asking if backwashing changed your numbers drastically? not unless you did a ton and added a lot of water back.
    a lot of people live with a cc of .5 or less, which is ok. but greater than .5 is not ok.
    pool-school/shocking_your_pool
    May 2009
    Trenton NJ
    497
    Does this sound right? fc-7.5
    cc-1
    cya-80
    Pool cal. says I need 7 gallons 1qt. of bleach.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by ethany
    cc-1
    cya-80
    Yes.
    That should take your FC to about 30 (based on your CYA 80).
    You're done SLAMing when:
