Thread: Use of aquadoor
    Use of aquadoor
    Hey guys. 1st time I will be closing a pool. We have a doughboy and we have the aquadoor cover which is supposed to stop water from getting into the skimmer lines. The issue I see is that the return line is lower than the skimmer. I assume when I close I will still need to empty the pool to below the return jet line. I do not have any type of plug for the return line and not sure I would trust it anyway. What does everyone else do?
    Other questions.
    I have hard lined my plumbing. When I blow out the lines where is the best point to do it from?
    Sand filter. Just remove drain plug and that's it?
    thanks
    12' x 24' (21100 gal) Doughboy Desert Spring w/ Deep End, Hayward SP15922S Power-Flo Matrix Above-Ground Pump 2-Speed,
    Hayward S210T Pro Series, Hayward H100ID1 H-Series , Hayward AQ-TROL-RJ AquaTrol Salt, TF-100
    Jun 2012
    western NY
    1,558
    Re: Use of aquadoor
    I use an aquadoor. For the return, I remove the eyeball and screw in a 1.5" plug into it. No problems all winter. I usually have to pump about 3-4" of water out of the pool in the spring. I do disconnect the pump for the winter and put it inside the barn so it is out of the weather.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Re: Use of aquadoor
    So do you drop the water level below the return as well? Also why do you end up having to pump out water
    Thanks
    Jun 2012
    western NY
    1,558
    Re: Use of aquadoor
    Nope I leave the water level up. My cover leaks slightly and when I tension it in the spring to get the winter debris off of it water leaks thru into the pool.
    Re: Use of aquadoor
    Thanks for the info
