Thread: Closing pool with potential algae - What happens?
    Today is the day to close the pool. It appears as if algae is just setting in. When I open it in the spring, I am usually dealing with some very dirty water. It takes a week and I have it to where I can see the bottom. My question, what happens if I close the pool now? Does algae grow like a tree and I will be dealing with even more matter to take out in the spring? Or will algae just be present...freeze off in the winter...slam it in the spring...and water is back to normal? Wanting to know what problems I will be creating for myself. Thank you.
    29K Gallon, Concrete bottom/Fiberglass sides, SWG, Sand Filter, 1HP Pump, Gas Heater
    Kansas City, KS
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    Re: Closing pool with potential algae - What happens?
    I have to ask why you are closing the pool now? I did a search for your weather and it says you are hitting in the 80s for some time to come. That is algae growing weather
    Is there any way you can wait? Do a SLAM, get it clear, close when your temps are down to 60 or so. We have a link and area just for closing pools. We can help you do it and save some money if you are paying someone to do it.
