Thread: Need Recommendations on a Liquidator Build
    Apr 2016
    Las Vegas
    20
    Hi all,
    I tried reading some of the older posts on this, but I haven't been able to put together the "complete" package of all what should be entailed in my LQ build. While I plan to have a pool guy install it, I want to be entirely aware of what should get installed and the "best" way to implement. I know I need the 3/8" upgrade. I'm dealing with a variable speed pump in which every Friday its run at near top speed, so if there are any tips on accomodating a VSP then please let me know!
    So what I need is a listing of all the parts that are needed/recommended for a proper LQ build.
    Thank you in advance for your advice!
    Keith
    -KP
    Specs:
    IG Pool, ~20,000 gallons, re-plastered in 2015.
    1.5" plumbing, single drain/skimmer.
    Pentair Intelliflo 2 VST Pump, Clean & Clear 420 Cartridge Filter
    Dec 2011
    Prosper, Texas
    124
    Re: Need Recommendations on a Liquidator Build
    Since you have a variable speed pump I would recommend a stenner pump over the liquidator. The liquidator needs to be set based on your flow rate and since you will be changing your flow rate it would be a challenge to get consistent results with one.
    21,000 gallon pool w/spa, Pebble Sheen, Hayward EcoStar variable speed filter pump, Hayward DE6020 Filter, Hayward 400FDN Heater, Stenner pump with 15 gallon tank, Clear O3 ozone system, Hayward Goldline PS-8 controller, Hayward 6060 cleaner pump, Polaris 280 cleaner, Hayward EcoStar variable speed water feature pump.
