Results 1 to 8 of 8
Thread: Phosphate Remover
    Mar 2016
    Friendswood Texas
    47
    Phosphate Remover
    So our PB says that we have to have a pool store test monthly for the plaster guy to warranty his product. Which is not a huge deal. So with me using the TFP method my numbers are great, which I knew before we took the water sample in. From what I have read when your numbers are good the store goes to the Phosphates test to try to sell you something. the test says we are @ 500 ppb. We have a bottle of phosphate remover that the PB gave us when the build was finished. Is there any harm in using it if I cant return it or should I just give it to a neighbor that will probably need it due to using only trichlor to sanitize their pool?
    Thanks
    Jeff
    Friendswood TX, 23x39 free form , 20K gallons , 3 HP VS pentair , 1 HP whiisperflo, Pentair easy touch , 400k BTU pentaier heater, Deck Jets, Pentair 5g LED Lights. Tanning ledge with bubblers. Taylor 2006 test kit
    triptyx's Avatar
    Apr 2016
    1,438
    Re: Phosphate Remover
    Why add something you don't need?
    I know it's hard when you've spent money on a product - you really, really want to use it to feel like you didn't "waste" the money. But in this case, if you can't return it, I'd personally give it to a neighbor that believes in snake oil - they'll feel good about saving some money on a product they use (and extend you some goodwill for giving it to them!), you'll feel good that it didn't go to "waste", everyone wins.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Jun 2014
    15,221
    I agree. I had the exact same situation when I learned about TFP. My bottle of Phosfree/Pool Perfect? ....... in the trash. Lesson learned for me. Have a nice weekend.
    Teald024's Avatar
    Aug 2016
    Columbus, Ohio
    1,141
    The builder / store that we bought the pool from also recommends the Phosfree/Pool Perfect product. In my short time learning the TPF process, I haven't heard any mention so far of any need to test for or deal with phosphate levels. Store guy says it's to remove phosphates that the 'lil critters like to eat. It was said by the store to add a bit each week and a whole lot more at closing.
    Using the TFP method, is it that we don't care what the phosphate level are since we are already suppressing the 'lil critters with chlorine or some other reason? My question is on phosphates and the need to deal with them or lack of any real need to do anything other than to clean debris and filter the water.
    - Dave -
    Dave - Aqua Leader Elegance AGP 15'x30'x 54", 12k gallons, vinyl liner ... Hayward/SwimPro Voyager pump SW159412STL, 2hp, 2spd, Hayward/Voyager 175sf element filter SW175MDDVPAKS, Installed August 2016 ... Liquid Chlorine, Stenner, Woods 50015 timer ... TF-100 .... CYA/Chlorine Chart ... Recommended Levels ... Basic Care Schedule ... Extended-Test-Kit-Directions ... ABCs of Pool Water Chemistry
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Ok....I think what *I'd* do is hold on to it. IF and when I ever needed to make a claim on my warranty and need the PB to come inspect my pool I'd use it at that time before they arrived and have a fast trip to the pool store for a test showing the phosphates were down or gone.
    Sure, it's a little sneaky but geez.... it makes more sense than them relying on a monthly pool store test to show the water is "balanced", right??
    Yip
    30,431
    That's correct. In fact, we don't "suppress" them, we eliminate them.
    Phosphate remover is a two-pronged loser.
    1. Algae can eat other foods (like nitrates) so you can't "starve" algae by removing phosphates.
    2. If you never have algae to begin with, algae food is irrelevant.
    Mar 2017
    Houston, TX
    86
    Quote Originally Posted by jeffnsheila View Post
    Thanks
    Jeff
    We have a new pool, and I've been keeping the pool chemicals balanced daily. I'm new to using the TF-100 and testing for CH, so I went to my local pool supply store to see what numbers they get. On a side note, I do think my CH tests are off, either b/c I'm not quite experienced at testing it and possibly b/c I'm not using the speedstir, which I've just ordered.
    So, the store's results showed that all my chemicals looked great EXCEPT for phosphates! At 1,000! It made me suspicious, b/c I know phosphates aren't supposed to be a key chemical, and it tested at only 100 a couple weeks ago, and then I found this post. I do believe that b/c I told him I test at home and my results are all pretty balanced, the only thing they could fudge was phosphates, which I don't test...
    He then subsequently tried to sell me PhosFree for $35 and then another phosphate-related chemical for $80!!
    First time pool owner
    21K IG; quartz plaster finish
    Pentair 1HP Whisperflo pump; Pentair Clean and Clear Plus cartridge filter; Pentair Mastertemp 400K BTU heater
    Polaris 280; Completed Feb. 2017
    Jan 2012
    7,367
    Good for you for recognizing that little sales trick they try to use.
    Yip
