Thread: Pitting corrosion on aluminum coping
    I am getting pitting corrosion on a section of aluminum coping closest to the equipment pad. I assume this is due the SWG system. How can I repair the coping to fill the holes?
    IG
    Fiberglass
    35,000 Gal
    Cartridge
    Flow rate on filter coming soon
    JoyfulNoise's Avatar
    May 2015
    13,173
    Re: Pitting corrosion on aluminum coping
    Can you post a picture?
    Generally speaking, you really don't want aluminum anywhere near a pool and certainly not near an SWG pool. If you do have aluminum, then it should be anodized aluminum. Also, any aluminum near the pool should be tied to a sacrificial anode (magnesium works best for aluminum). This will slow down the corrosion.
    Matt
