Thread: non chlorine oxidizer question
    Jun 2016
    Florida
    32
    When would it be beneficial to add a non-chlorine oxidizer to your pool and why? Curious about the appropriate usage of it.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: non chlorine oxidizer question
    For outdoor pools, there is no practical reason that MPS (non-chlorine oxidizer) needs to be used. Typically, MPS is used in spas and indoor pools more often because it helps more quickly oxidize residual CC (combined chlorines). In outdoor pools, sunlight does an excellent job of eliminating CCs. MPS can be used to oxidize bather waste in an outdoor pool, but liquid chlorine is much more economical. MPS is not actually an approved sanitizer, like chlorine but can be useful in some situations.
    Isolated Spa - 345 Gallons
    Jun 2016
    Florida
    32
    Does it have any reaction with chlorine?
    Feb 2014
    Central Minnesota
    5,080
    As far as I know, they do not react with each other. They're more teammates than adversaries. Both oxidize organics, some better than others. MPS will show up as false positive CC for a up to a couple days after adding, unless special reagents are used for testing.
    JoyfulNoise's Avatar
    May 2015
    13,199
    This is an excellent post by chem geek regarding MPS oxidation - Chemistry of Chloramines - indoor commercial pool
    Matt
    Jun 2016
    Florida
    32
    Thanks!
