Thread: Which pebble finish?
    Jun 2016
    East Central MS
    116
    We will be completely re-doing our pool this winter and installing a pebble finish. I have read historically on this forum that pebbletec is preferred by many. Does it really matter? If so, which pebble finishes should I consider? Are there any I should stay away from? Thanks for your opinions in advance.
    34K gal, 20'x40' IGP (backfilled and reinforced concrete block walls with concrete floor built mid-1970's; renovated 2017), PebbleSheen Arctic White plaster finish, Lotus Prisma Marine 1x2 glass waterline tiles, Indiana limestone coping, 1.5hp Hayward pump, Pentair Triton II TR100 sand filter, Pentair Intellibrite 5g color LED 120v Pool Light, Dolphin Supreme M400 robot, Stenner 45M1 pump, Pentair 320 chlorinator (to raise CYA only)
    Rsmith's Avatar
    Apr 2016
    Central Md.
    110
    Re: Which pebble finish?
    This should be a fun thread to watch.
    Central Md. 37 X 21 24K IG Custom Gunite with Anvil Quartz finish. Raised Spa.
    Sta-Rite Natural Gas Heater. Intellichlor IC-40 SWG, Sta-Rite 450 sq ft. Cartridge Filter.
    Pentair 1.5 Hp Variable Speed Pump. TF100. Dolphin Z-5. First swim 5/26/16
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    I've seen several pebble manufacturers that people are happy with! I have Wet Edge, Stonescapes is one I've heard about and seen great pictures of also, Diamondbrite, etc.
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    Aug 2014
    Houston tx
    2,524
    I'm no expert, but I believe that they are all basically the same. PT does have a longer warranty than the others, but what's MOST important is the quality of the application. Check out the reputation of the plaster company and see other pools they have done. Blue plaster tends to mottle more than others, so look at that aspect too. Good luck and have fun!
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
