Thread: How the TFPC method eliminated my pool maintenance stress
    Jul 2016
    Carlsbad, CA
    29
    Red face How the TFPC method eliminated my pool maintenance stress
    I am so glad I discovered the TFP site, and am grateful for all the knowledge contributed by the members. I have yet to see a book that explains everything I've learned about pool chemistry from this site. I knew that I was not getting a straight or consistent story from the pool stores, and for years I struggled with algae. I knew that high CYA was bad, and that the tri-chlor tabs I was using steadily increased the CYA. It was only at the TFP site that learned that I could stay out of trouble by keeping a proper FC/CYA ratio, and that I needed to get an FAS-DPD test kit to accurately measure the amount of FC needed. My local Leslies store does not even have these kits available in the store, so I had to order it online. One guy at the store even claimed I could avoid getting too much CYA in the pool by only putting a couple of 3 inch tabs at a time into my in-line chlorinator, instead of filling it full of tabs. Sigh!
    I've had no algae problems since I started the following routine: I now use only bleach and muriatic acid for normal maintenance. Early each morning I check my chlorine with the FAS-DPD test, and if necessary I add enough bleach to bring it up to at least the target FC level in the "Chlorine/CYA chart", or at least 2 ppm above the minimum FC level, based on my current CYA level. I usually lose between 1.5 and 2 ppm of FC per day in the summer, so this generally keeps me at or above the minimum FC level after a full day of sunshine. I normally don't lose any FC overnight, so I check it again next morning, and I find it is always at or above the minimum FC level. The CC stays at zero, and I never need to shock it regularly (as the books and pool stores tell you to do). I don't need algaecide. After a day with a bunch of kids swimming for hours, my CC temporarily went up to about 1, but after a day or two it was back below 0.5, without shocking - just keeping the FC level at or above the recommended level. I keep a daily log of my measurements and the amounts of bleach or muriatic acid added, so I can anticipate my pool's needs. It's very easy and doesn't take much time, once you have a system. On a day when there has been a bunch of people in the pool, I will check the FC at the end of the day to make sure it didn't drop too low, but otherwise I only check it each morning.
    When I am going to be away for a week or more, with no one to do the daily checking, I start using my in-line chlorinator with 3" tabs a day or two before I leave, so I can get it adjusted right. On my latest trip, I set the flow rate dial so that it would consume about one-half tablet per day*. In my pool, that should add 1.7 ppm of FC per day and 1.0 ppm of CYA (knowledge I gained on the TFP site, of course). My CYA was about 55 before I left, and I adjusted the FC up to about 9.5 in the morning. When I returned 7 days later, my morning FC was 10.5. About 3.5 tabs had been consumed during that time, so I figured that the chlorinator had added about 12 ppm of FC and 7 ppm of CYA during the 7 days I was gone. And thus the sun must have consumed about 11 ppm of FC during that time. I measured my new CYA level and it was around 60 to 65 as expected, so I will increase my FC level appropriately. I found that keeping a higher FC level does not seem to require me to use more bleach, since i only have to replace what the sun consumes each day.
    If I take enough trips, with each trip requiring me to add 7 to 10 ppm of CYA (by using tabs), I know that eventually I will need to drain and replace the water, but at least now I know how to keep the proper FC levels and avoid algae, as my CYA gradually goes up. Thank you, Trouble Free Pools!
    * My crude way of estimating the rate of tablet consumption is to measure the distance from the top tablet to the top of the feeder tube before and after a 24 hour interval. Since each tablet is 1.25" thick, if the level went down by 0.625", I know that it has dissolved half a tablet per day, and for my pool it has added 1.7 ppm of FC.
    16,000 gallon outdoor in-ground 16'x32' plaster pool (built 2002); Pentair Intelliflo VF pump; Jandy Cartridge filter;Rainbow in-line chlorinator (used only when I am away); Hayward 2 wheel suction-side pool cleaner; LARS gas heater, Taylor K-2006 FAS-DPD test kit
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Re: How the TFPC method eliminated my pool maintenance stress
    Excellent post! Thank you.
    12,000 Gal, InGround, Spa Attached, Satin-Matrix Northshore Tahoe Pebble-Tec, Remodel 6/15, Taylor K-2006 Kit, Pentair IntelliFlo Variable Speed Pump, Polaris 280 Sweep, Jandy CL460 Cartridge Filter, Solar Heated. Taylor K-2006 Test Kit
    Jul 2009
    Long Island, NY
    267
    Well said! It's great to see when someone has a really good understanding of their pool.
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    It is nice to see someone grasping the concept so thoroughly!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,539
    Post of the YEAR here! WOW! THANKS! I hope you stick around and help out any newbies or oldbies as needed!
    Sidecarist's Avatar
    Jun 2015
    Dayton, TN
    76
    Except for slight differences in equipment (I have a SWG) my story is much the same. It is a pleasure to not worry about the pool. If I do my part it will stay clean clear and most importantly sanitized.
    Another TFP success story!
    Congrats!
    12,000gal Fiberglass In Ground, Pentair 1hp single speed pump, and Pentair 100sq/ft single cartridge filter. Intellichlor IC-40 SWG, Roof mounted 400ft solar heat loop, Zodiac MX8 Elite cleaner w/leaf canister
    Taylor K-2006-C, Speed Stir, Taylor K-1766 salt test
