Results 1 to 13 of 13
Thread: Install a Spa light niche into a pool light niche?
    Sep 2016
    Escondido/CA
    638
    I've got a pool light in my Spa. It is quite bright.
    Im wondering a few things:
    1) if I switch to a spa light, will it really knock down the brightness commensurate with the effort?
    2) can I pile cement into the pool light niche and inset a spa light niche without too much trouble?
    3) has anyone done this? Or is this a better job to give to a pool contractor?
    4) can I do the plaster "repair" myself?
    5) will I need to keep the spa empty for a month before I can refill with salt water?
    6) better to wait a few years till I drain, acid wash, and refill?
    7) what am I not thinking about here?
    Jon -- 28kgal, IG, AquaBright, Attached Spa, ~1990, Quad DE 80, Easytouch8, IntelliFloVS-3050, Intellichlor60, IntelliPh, Dolphin DX6, City Water, K-2006/TF-100, SpeedStir, SampleSizer, San Diego, CA
    Jan 2015
    las vegas
    92
    Re: Install a Spa light niche into a pool light niche?
    Change the wattage of the bulb, make sure to replace gasket instead of using the old one.
    Jul 2015
    San Marcos, CA
    110
    Why not install a dimmer on the switch?
    16 x 32 IG plaster pool, 23k gallons, built 1992, DE filter, Pentair VS pump, IoThyngs controller, Taylor 2006 test kit, SoCal water restrictions
    Newbies with green pools, see SLAM and Recommended Test Kits. My company: IoThyngs
    Sep 2016
    Escondido/CA
    638
    Quote Originally Posted by lasvegaspools View Post
    Sent from my SGP561 using Tapatalk
    I'm using intellibrite color LEDs so this isn't an option.
    Quote Originally Posted by Amail View Post
    I wonder if this is possible. Anyone know if intellibrite color LEDs can be dimmed? Might be a long shot but worth asking the question.
    Jul 2015
    San Marcos, CA
    110
    Ah, an Intellibrite LED. Per Pentair's documentation:
    THE INTELLIBRITE 5G LED POOL LIGHT AND SPA LIGHT CANNOT BE USED ON A DIMMER CIRCUIT. USING A DIMMER SWITCH WILL RESULT IN PERMANENT DAMAGE TO THE LIGHT.
    Jan 2015
    las vegas
    92
    Dimmers are not recommended for use with the intellibrite led. I have put globrite lights in place of large pool lights, requires patching and a transformer. Switching to a spa led would require bonding new light niche.
    Sep 2016
    Escondido/CA
    638
    Wow! Great info! That takes that good idea off the table. Bummer.
    Sep 2016
    Escondido/CA
    638
    Any ideas with respect to my original questions about a smaller niche?
    Jan 2015
    las vegas
    92
    Smaller niche still needs to be bonded, this would mean jack hammering out gunite to expose rebar. So yes you can do it but it is more involved than just sticking the smaller niche inside the larger one.
    Apr 2015
    tucson, arizona
    1,120
    Hydrel Adapter Ring Parts - INYOPools.com
    , using this adapter ring might work
    Sep 2016
    Escondido/CA
    638
    Quote Originally Posted by kadavis View Post
    PERFECT! this would be awesome.
    Now if I could just find someone that would still have one in stock. They seem to have been discontinued years ago. I'm still looking though.
    Sep 2016
    Escondido/CA
    638
    Quote Originally Posted by xyz View Post
    Bummer. No where to be found. Seems this has been obsolete for many years.
    Apr 2015
    tucson, arizona
    1,120
    They didn't have them, try calling them
