Thread: Winterizing Sand Filter...
    May 2016
    Chicago, IL
    23
    Well, Summer is about gone at this point and time to start packing it in for the year. I've an above ground pool with a Hayward 16 In Sand Filter System W/1Hp filter (Item # S166T1580S) and aside from tossing the sand, giving it a thorough cleaning and bringing it inside, is there anything else that's necessary?
    Many thanks! Fantastic forum here!
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,248
    Re: Winterizing Sand Filter...
    Hayward Manual for the S244T 24" 300# sand filter, states only this in their instructions for winterizing. Same procedure for all Sand Filters with Multi-Port.
    WINTERIZING
    1. Completely drain tank by unscrewing drain cap at base of filter tank. Leave cap off during winter.
    2. Depress Vari-Flo control valve handle and rotate so as to set pointer on valve top between any two positions. This will allow water to drain from the valve. Leave valve in this "inactive" position.
    Below is also a thread. Please do not forget to remove the pressure gauge and sight glass.
    winterizing with a sand filter
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    May 2016
    Chicago, IL
    23
    Quote Originally Posted by Catanzaro View Post
    WINTERIZING
    Many thanks, and thanks for pointing me to the thread!
    Aug 2014
    Northern IL
    4,615
    If you possibly can, wait until your pool temperature gets to be 60 degrees for a while before closing. It will really help with spring opening, especially if you open when the water temp hits 60 again. I do this in the western suburbs and I open clear and balanced...
