Thread: thought i was done- but maybe not
    started converting a cpl weeks ago and thought i was done as pool
    cleared up and turned beautiful. but i have noticed that when i shock
    pool it turns slightly green. i have my tf test kit now and here are my results:
    is this an indication that all the baquacil isn't gone yet?
    24,000 gallon ig fiberglass pool
    1 hp hayward pump
    hayward sand filter (250 lb)
    madisonville, ky
    Re: thought i was done- but maybe not have high need to hold your FC at shock levels (12 in your case) until the CC are all gone...
    25,000 gal IG Utopia pool/Raypack gas heater/BBB
    Butterfly's Avatar
    South Carolina
    Did you follow ALL the steps in the conversion article?
    Convert Your Baqua Pool to Chlorine?
    You're done SLAMing when:
