Thread: New Start Capacitor, Motor worked, then slowly stopped
    Sep 2016
    Porterville
    2
    Turning the pump motor on at the Timer box, the motor just hummed... I installed a new start capacitor, and then the pump did come on for about 20 seconds and then it slowly came to a stop. It would not click on at all anymore after that, not even a hum. Any ideas?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: New Start Capacitor, Motor worked, then slowly stopped
    First, welcome to the forum!
    A couple things to check:
    Did the breaker or GFCI trip?
    After 30 min, will it start again?
    Mark
    Sep 2016
    Porterville
    2
    Thanks... It just slowly ran down then stopped. The breaker did not trip. Going back on Monday, i'll see if it will start up again.
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    167
    Stiff bearings as they fail along with a weak start capacitor likely caused your first failure. The new run cap gave it the extra torque needed to break free, but those worn out bearings warmed up and slowly seized up tighter until it stopped the motor. During that time it would have been over-amping, which likely caused the motor's internal thermal protection to trip. Once that cools down, you will likely be able to turn it on and watch it die all over again.
    Chris | 16' x 34' 16,000 gallon | IG Vinyl | Pentair Tagelus sand filter | Jandy 2hp epump | AquaPro PRO1300 heat pump | Coverstar auto cover | Taylor K-2006 | built August, 2016.
