Thread: trouble with fine dust in pool
    Feb 2015
    melbourne
    4
    Hi all, I'm still having issues with fine dust on the pool floor. Vacuuming it to waste removes it temporarily. It slowly comes back. It's not sand. It's very fine. My skimmer sock can't catch it. I think you all know what I'm talking about.
    My test numbers are all good. My equipment is all good. Pool is inground.
    I'd like to shock/slam my pool. I'm not sure how to do this properly.
    Can someone please advise on my situation and how to shock?
    I have a salt pool. 38,000 litres.
    thanks
    also, i'm using liquid chlorine.
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    859
    Re: trouble with fine dust in pool
    Hi and welcome to the forum.
    First thing we like to know is what test kit are you using? Also how does the water look- clear or cloudy. The fine dust could be dead algae but we really need some reliable test numbers from one of the recommended test kits. This will also be needed if you need to SLAM in the way that we recommend. This should be one of your first priorities. A version of the recommended test kit is available in Australia from Clearchoice Labs.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    domct203's Avatar
    Jun 2015
    CT
    3,505
    Quote Originally Posted by didierdrogba View Post
    thanks
    Hello and welcome to the forum!
    It sounds like you may have an algae bloom in progress, and you're correct, that would require a SLAM. A SLAM is a controlled and maintained period of shock level FC:
    How To SLAM Your Pool
    Can you please give us some more info on your pool? Do you have a SWG, or is it just a pool with salt added and you use liquid chlorine?
    To help us better understand your pool, can you please post a complete set of test results, and tell us how you test?
    We would like to see:
    FC
    CC
    pH
    TA
    CH
    CYA
    If you are unsure of those abbreviations and pool chemistry in general have a read here: The ABC's Of Pool Water Chemistry
    Once we understand your pool we can get you pointed in the right direction.
    Nice to have you with us.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Feb 2015
    melbourne
    4
    Hi, I have a SWG. I will post test results in the coming days.
    Thanks
    Feb 2015
    melbourne
    4
    Hi I've attached a few photos of the situation regarding the fine dust. Would just like to get some thoughts on what you guys think this is, now that I have the pics. Will be putting test results up soon.
    Thanks
    30,287
    You have algae in your pool. Get out that test kit (I would do it sooner than "a few days") and begin to SLAM the pool.
    Read the SLAM article in Pool School and follow it like it is your bible.
