Thread: Need recommendation: 2 speed pump or not? If so what timer to go with it?
    Well my 10 year old Hayward 1.0Hp Hydramax2 died tonight. I'm looking at 2 speed options and have found the following:
    Pentair 340042 SuperFlo High Performance Energy Efficient Two Speed Pool Pump but I'm not sure about what timer to use to be able to switch speeds automatically.
    Any suggestions?
    Also from the reviews these pumps are short on documentation. Any links to detailed wiring diagrams are appreciated.
    Thanks!
    16k Gal fiberglass over plaster
    Hayward CX900RE
    Leslie's HydramaxII 1.0Hp pump
    Polaris 280
    38,290
    Re: Need recommendation: 2 speed pump or not? If so what timer to go with it?
    Why do you think you need to automatically switch speeds?
    Before my solar controller was installed, I just left it on low for when it ran each day and manually switched to high when needed for backwash, cleaning, etc.
    I figured it needed to switch between high speed at start and low speed for longer times. I'm also looking at a variable speed unit
    Hayward SP2302VSP Max-Flo VS Variable-Speed Pool Pump
    Thanks in Advance for all opinions
    Hayward CX900RE
    Polaris 280
    38,290
    It can start and stop in low speed. You should not lose prime when the pump stops.
