Results 1 to 8 of 8
Thread: Lots of bubbling in my pool
    Sep 2016
    Houston/TX
    4
    I came out this morning and all I could hear was the gurgling sound and my polaris wasn't moving. Somehow I'm getting a ton of air coming into my pool and spa. During filter my supply comes from pool and return is about 50/50 to pool and spa. In testing I turned it to only supply/return to spa, no bubbles. I turned it to supply from pool and 100 to spa, no bubbles. So I don't think it is my supply line. I'm not seeing any water loss which this is where I'm thrown. How can be getting all these huge bubbles and not having any water loss. Where could all this air be coming from? Thanks
    30,432
    Re: Lots of bubbling in my pool
    air is being sucked into your system.....it has nothing to do with water loss.
    There is an article in Pool School "Suction Side Leaks".....see if that helps.
    Sep 2016
    Houston/TX
    4
    so even when I suck from pool and output only to spa I get no bubbles, if I suck from spa and output to spa I get no bubbles. So with your awesome post you still think it's a suction side leak. I hardly have any bubbles in my pump
    30,432
    Your post is a little confusing but you can always take to the bank that air can ONLY enter your system on the suction side.
    Major_in_MS's Avatar
    Jul 2016
    Florence, MS
    94
    Check the gasket/seal on your pump basket. It may not have sealed properly the last time you emptied it. When this happens it can pull a large amount of air into your pipes.
    Also, if something floating in your pool, like a raft, blocks the water going into the skimmer, then the pump will pull air from the skimmer. This will also happen if the water level gets too low due to evaporation or splash out. Look in your skimmer and see if you see a whirlpool pulling air down from the surface.
    24,200 gal., IG vinyl, 18' x 36' rectangular, average depth 5'. K-2006C
    Jandy SFTM22 sand filter, 1.65 HP PureLine VS Pump, Doheny's Discovery Robot.
    One skimmer, one main drain, two eyeball jets, and one return from the booster pump.
    One wife of 28 years (schoolteacher, first grade), four kids (ages 16,18,19, and 21).
    I work night shift (Pediatric RN) so most of my posts will be during the night.
    Sep 2016
    Houston/TX
    4
    Well I guess you were wrong for once in your life. Was the seal on my chlorinator which is not on the suction side. Thanks
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    Quote Originally Posted by barkster View Post
    So it was acting as an air injector like in a spa. Not on the suction side of the pump, but still under suction, the only way for air to get into the plumbing!
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    30,432
    There is no source of air pressure in an inline chlorinator. Pump running, a leak at the chlorinator will be a water leak.....not air
