Thread: Unique "filling the pool" question.
    Jun 2012
    Northern Kentucky/Cincinnati Area
    39
    Our installers came out today to fix an issue with the floor of our above ground pool installed a few months ago. The liner had divots after the floor was improperly packed I guess. We drained the pool, they pulled the liner off on the sides, filled and packed more sand into the affected areas and reset the liner.
    Here is my question:
    Am I okay to let my pool fill overnight since the liner has already been stretched once before? The floor of the pool looks great. I just don't want to damage the pool or liner. It was 85 degrees today and it is forecast to get down to 60-62 degrees tonight.
    Thanks for the advice!
    18'x33' Sharkline Harbortown AG, 16,700 Gal. 2HP 2 speed Pentair Optiflo pump
    150 sq. ft cartridge filter. TF100 Test kit with Speedstir!
    Jan 2012
    'burbs of Augusta, Georgia
    7,296
    Re: Unique "filling the pool" question.
    Sure.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,432
    The longer it sits without water the better the chance of a it not setting back where it needs to........fill it.
