Thread: FC confusion
    Sep 2016
    Wadsworth, OH
    9
    FC confusion
    I have the Taylor k-2006 test kit and I am confused as to what the results are actually telling me. When I measure the FC, I understand that does not include any CC that is currently bound to any bacteria, algae, etc.. I am confused when the CYA comes into play. When chlorine is bound to the CYA and is not an effective disinfectant, does it show as FC or CC?
    Fiberglass in-ground Viking pool, 22,000 gallons, 1.5 HP Jandy pump, Jandy 200 cartridge filter, Jandy jxi260 heater.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: FC confusion
    CC are essentially a biproduct of the chlorine oxidizing the bad things. It isn't "bound" to the bacteria.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Sep 2016
    Wadsworth, OH
    9
    Re: FC confusion
    Then chlorine that is not disinfecting due to CYA, will be included with the test for FC?
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,384
    Re: FC confusion
    CC is like charred & ash wood in a campfire - FC is a clean fresh log. ( it all came from a tree but the clean fresh long will keep you toasty)
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: FC confusion
    Here you go, read this, it will help clear things up. ABCs of Pool Water Chemistry
    Aug 2014
    Northern IL
    4,615
    Re: FC confusion
    Pooldv's link is perfect. Please read that.
    Simply put, testing shows the "CYA-bound" chlorine as FC, not CC.
