Thread: Intex portable pool chems
    Jun 2007
    Virginia, USA
    8
    I know this is a silly question, but can anybody recommend what chemicals should be used in the "Intex" portable pools?
    SunEnterprises.com Placing orders over the phone will expedite the process. Online orders usually add a day or 2 to the process. Im at extension 232
    If you have a circulation pump then you use the same chemicals you would use in any other pool. See the Stickies section of this site for details, there is a link in the sub-heading of each page.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Intex portable pool chems
    Quote Originally Posted by SunEnterprises
    Stick with liquid chemicals when you can to avoid cloudiness that your filter won't deal with well.
    Bleach for chlorination and shock. Add it slowly or mix a cup or so in a bucket of water and add to the pool.
    Muriatic Acid to lower pH. Mix about a cup at a time in a bucket of water before adding it to the pool.
    If you have to raise the pH, use Borax. Dissolve it in a bucket of water before adding it to the pool.
    Add CYA or stabilizer to about 40ppm to protect the chlorine from the sun. Best way to add is by placing it in an old sock and hanging it in the water.
    Run your filter 24/7 except when the water looks perfect. Check your chlorine twice a day and your pH every couple of days.
    Jun 2007
    Virginia, USA
    8
    Thanks so much. I was just curious if the regular pool chemicals would affect the liner. I guess I just questioned its durability, but it seems it can be treated the same as a regular pool. I appreciate your help.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Those softsided pools have a pretty tough and heavy duty vinyl liner. How would the durability be worse than a 15 or 20 liner that goes into a pool frame or IG which is probably a lot thinner?
    Chlorine is chlorine. How it is used matters more. Too many people get those pop ups and just dump a pile of granular in to sit on the bottom or load a floater up with as many pucks as they can and leave it. That is whats gotta be tough on them, but they really get little or no instructions for water care anywhere. Intex makes a couple of SWG now that will work on those pools (and even one that can go on pools up to 14600 Gal) Thats a leap forward anyway.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Jun 2007
    Virginia, USA
    8
    Thanks NWMNMOM, thats exactly what I was referring to. I can see a ton of our customers doing exactly as you spoke of. Dumping a bucket of granular and letting it sit on that vinyl. I hear tons of horror stories. I dont know what some of these people are thinking...On this forum I am exposed to intelligent people, who are knowledgable about pools, then I answer the phone and get calls like, do you all sell liners for intex pools? yes thats a real question. Thanks so much for your input. have a great weekend - Tim
