Thread: Chlorine use high cc low
    48 hrs ago my fc was 8 ppm prior to hot tub use with cc 1 or less ph was 7.8 ta 60
    Ch130 cya 60 borates 50
    3 of us were in for 30 min so I added another 7.5 Oz of chlorine
    Now 48hrs later there is .5ppm or less
    Should it drop so fast? Do I literally have to check daily? What if I'm gone for a few days or a week?
    Located in Ottawa, Ontario Canada
    23K Gal, AG, Cart filter, 1.5hp 2speed hay PowerFlo Matrix, Install Sum'13, Aquatrol SWG, Solarbear panels, kreepy Krauly E-Z Vac, TF-100
    Artesian ~500gal Grand Gayman Island Spa
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: Chlorine use high cc low
    Can you post full results? What is your CYA.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    This has some tips to help you determine your chlorine consumption and dosing schedule. How do I use Chlorine in my Spa (or pool)?
    Quote Originally Posted by AimeeH View Post
    I believe I did post full results.
    CYA 60
