Thread: CC high after SLAM
    Jun 2016
    Jackson NJ
    97
    CC high after SLAM
    Hi all,
    So we had a full algae bloom and SLAMed the pool for a week. Water was totally clear and FC read 17, CC 0, passed overnight test.
    Let it drift down for 30 hours and now the reading is
    FC 2
    CC 1.5-2
    TA 80
    pH 7.5
    CYA 30
    What does the CC reading indicate...am I going to have to start a new SLAM? I really dont want to...its almost time to close the pool
    Vinyl IG 18x43 25,000 gallon
    Hayward Pro s244T 300 lb Sand (with occasional addition of clarifier)
    1.5 HP pump; Polaris 380 with booster pump; Hayward H400 gas heater
    TF-100 with SpeedSTIR
    30,431
    Re: CC high after SLAM
    Bring your FC up to around 6 ppm and HOLD IT THERE for maybe 48 hours or so. Then test CC's again.....my thinking is they will be .5 ppm or less.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    It may indicate that you still have hidden algae in your pool, did you check low circulation areas like under steps, ladders, and in light niches?
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Did you add anything else to your pool such as algaecide?
    Jun 2016
    Jackson NJ
    97
    Didnt add anything but the liquid shock/bleach.
    Raised it up to 8 for 24 hours and tested again today and CC was 0 so we are good to go. Thanks.
