Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: intex ultra 18 foot pool.. winterizing tips / suggestions, the best cover to use?
    Jun 2016
    Pittsburgh, pa
    360
    I'm getting pretty close to closing down the pool for its first year up.
    I think i understand the basics of the steps to winterize it..
    -drain the water down to just below the two intake holes
    -take off all the pumps (salt water and regular pumps/sand pump) and store in house (not garage)
    -put an inner tube in the middle of the pool
    -pull out the steps from the pool, maybe place on the deck for the winter (plastic).
    -put the cover that came with the pool over the pool (tie down somehow)?
    Did i miss anything here?
    I assume i should pull the steps out of the pool, otherwise the cover wont really cover that area.
    I also am unsure on the cover.. the one that came with the pool.. is it good enough.. i cant recall, but i thought it had small holes in it, which may or may not matter?
    If the cover it came with is no good, any suggestions on an alternative.. or just an 18 footer from amazon with good ratings?
    Thanks in advance
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Re: intex ultra 18 foot pool.. winterizing tips / suggestions, the best cover to use?
    I joining in for the answers.
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
    Jun 2016
    Pittsburgh, pa
    360
    Bump..
    Any input anyone?
    Thanks
    Jul 2012
    SE Minnesota
    137
    The cover that came with the pool is full of holes and it will slowly sink. This is my first year closing also but I would not use the cover that came with it. I used it during the summer and it is starting to fall apart after 3 months. I don't think it would hold up after a long winter.
    Intex Ultra Frame 26'x52"
    Intex 2,500 gal/hr pump with Unicel cartridge filter.
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    Looks good,
    I would replace the cover, like you stated. To hold down the cover I save my gallon chlorine bottles and fill them with water to hold down the cover.
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
    Jun 2015
    Georgia
    13
    This will be our second year closing our pool. We had a great swimming season following the TFP recommendations here last year, but our first close was an epic fail. The Intex cover allowed a bird to get in and it died and rotted in the pool. I then decided that the pool must be drained because that is just nasty. We are looking at how to close it better this year. We also are getting a leaf cover this year for sure.
    Suburbs of Atlanta, GA
    Brand new pool and learning as we go!
    Intex 18 x 48 Ultra Frame Pool
    Filter that came with it
    Intex 120V Krystal Clear Saltwater System
    - not using yet
    Jun 2016
    Pittsburgh, pa
    360
    I'm not finding many to choose from on Amazon unfortunately, at least none rated that highly.
    Jun 2016
    Pittsburgh, pa
    360
    Actually found this one for $35 which may be ok? Gorilla 18 Amazon.com : Economy - 18 Garden
    Then another which averages $50 which might be ($50 via jet): Swimline Ripstopper RIG18 Amazon.com : Swimline 18-Foot Round RipStopper Pool Cover : Patio, Lawn Garden
    and possibly this one
    Swimline S18RD $46 Amazon.com : Swimline S18RD 18 Garden
    domct203's Avatar
    Jun 2015
    CT
    3,384
    I covered my 18' with a 21' pool cover, making sure that the cover touched the water so it did not pull the walls in when full of snow. I used the ratchet/wire to tighten the cover to the pool, then laced it to the bottom rope on the pool. I then topped that with a leaf cover that came off when the trees were empty.
    I plan to do exactly the the same this winter.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2016
    Pittsburgh, pa
    360
    Quote Originally Posted by domct203 View Post
    nice.. what brand cover is that..swimline?
    domct203's Avatar
    Jun 2015
    CT
    3,384
    Quote Originally Posted by theskyisthelimit99 View Post
    I honestly don't know. It's whatever brand my local OSJL carries, and was only $40 or $50.
    It should make it for another winter or two no problem, after that I figure I got my money's worth.
    I didn't want to spend a lot on the cover as I only planned on three to five seasons out of the Intex, which will get replaced with a larger hard-walled pool.
    Dom - TFP Guide
    Oct 2016
    Cheektowaga, NY
    1
    Hello, did you leave the filter on? Or drain below the filter?
    domct203's Avatar
    Jun 2015
    CT
    3,384
    Quote Originally Posted by Nicspen80 View Post
    I drained the pool to just below the skimmer & capped off the original suction port. The pump & multi port valve was stored in the house, the sand filter was deep cleaned, drained and stored in the garage (it only holds 75lbs of sand, easily moved with two guys and a wheelbarrow). I used a rag (old T shirt) to cover the opening from the multi port valve, and held it there with the original band clamp.
    I had planned to do the same this year. Next season will see a much larger sandfilter (200lbs of sand), so that will have to stay on the equipment pad over winter. I will most likely build a box cover to keep the weather off of it. The pump & multi port will always be stored in the house.
    Dom - TFP Guide
    Oct 2016
    Fort Worth, TX
    17
    Hello, I'm joining this thread because I'm not getting responses in mine! I have the rectangular Intex pool so I can't really drain below the intake valve (the sides will bow/bend in a lot). When you say you capped off the suction port, what did you use as a cap? I have thought about getting a plug and trying to put that in underwater, but I'm not sure that would work. Is it ok to just disconnect the hoses and close the valves? I am in Texas and I really don't think the pool water would freeze solid. Also does anybody have experience using pool wrap (like the saran wrap that you wrap around the pool to keep the cover sealed)? I had to buy an oval pool cover because nobody makes rectangular above ground pool covers. Finally, I read in some places that the water temperature needs to be below 60 degrees before you close the pool. Why is that necessary? But if I do that it could be December! It is still in the 90s here and my air conditioner is running. I really want to close this pool!
    domct203's Avatar
    Jun 2015
    CT
    3,384
    Welcome to the forum.
    I use the cap from the waste port on my sand filter. I made a custom flat rubber washer to use with it, I got the rubber materiall from a buddy that is into boats.
    The reason we wait until the water gets to below 60 is because at those temps algae is extremely slow to reproduce. This, coupled with shock level FC at close gets us through the winter.
    I'm not familiar with closing a warm weather pool, but once we (solid) cover ours, I don't check or maintain chemicals or circulate the water all fall/winter. I would imagine that with warmer water temps you would need to maintain FC and circulate water a bit.
    Dom - TFP Guide
    Oct 2016
    Fort Worth, TX
    17
    Thanks, I got the In The Swim winterizing kit, it comes with a floater that I believe delivers chemicals for a couple of months at least.
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    666
    I really believe no cover is the best for this style pool.
    Oct 2016
    Fort Worth, TX
    17
    If I don't cover it, then don't I have to add chemicals and run the pump year-round? I bought a cover, air pillows, leaf net, winterizing kit and everything already. Only got a couple of replies in the post I started but they said they cover.
    domct203's Avatar
    Jun 2015
    CT
    3,384
    I believe that poolguy's concern may be the cover pulling in the sides of that pool, something that concerns me as well.
    When I close my pool, I lower the water to just under the skimmer, which works out to about an 1" below the return jet, the suction port is still under water. I was not comfortable going much lower with a soft-sided pool.
    When I cover my pool, I use an oversized cover (21' for my 18') so I could lay the cover flat on the water, right up to the sides of the pool, & follow up the pool wall. This way the snow & ice weight is supported by the water, not hanging like a hammock & pulling in the sides of the pool.
    Here's the only pic I have where you can somewhat see this, through the leaf cover which is drawn tight across the pool:
    Dom - TFP Guide
  20. Back To Top    #20
    domct203's Avatar
    Jun 2015
    CT
    3,384
    Quote Originally Posted by inkybrown View Post
    I'm sorry to hear you spent money on things you may not need, but I don't see anyone in that thread specifically telling you to cover that pool. I see one post where someone mentions that they cover their 18' round pool.
    http://www.troublefreepool.com/threa...95#post1143595
    Your rectangular pool is a different challenge as you know, due to the sides naturally pulling in. The round pools do not have that issue.
    If your suction and return ports are like mine, you could pick up a few covers and cap them so you will not have to drain as far, but there still is risk of freezing water inside the fittings if they are very close to the top of the water.
    How much bigger than the pool is the cover? What does this "winterizing kit" contain?
    Dom - TFP Guide
