Thread: Can you close a pool immediately after shocking it
    Aug 2016
    Piscataway, New Jersey
    5
    Question Can you close a pool immediately after shocking it
    If you shock a pool (with liquid chlorine) as you get ready to close it do you wait for the level to drop to the recommended FC level (based on CYA reading) or can you close it with the higher FC level that results from the shock?
    7800 gal, vinyl, A/G, 100 sq ft Proline cartridge filter, 1 hp Hi Flo pump, installed 2006, Taylor K2006 test kit, Raypak 130K natural gas heater, chlorine tab feeder, Pool Rover cleaner
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Can you close a pool immediately after shocking it
    You can close it with the elevated FC right away, as long as you don't exceed the shock level FC from the FC/CYA Chart.
    Isolated Spa - 345 Gallons
