Results 1 to 11 of 11
Thread: New Construction - Foiled by weather...again....and again....and again....
    Aug 2016
    Cameron, MO
    14
    Pool builders started building our Vinyl IG 18x36 diving pool on 8/22/16. "If the weather holds out, you will be hosting a pool party on Labor Day", the builder proclaimed. And then the rain started.....and...it...won't...stop...UGH.
    We are now waiting for the concrete decking and was hoping to get it poured today. But it started raining this morning and hasn't stopped! And the forecast shows rain the next four days!!! I feel so defeated at this point. Maybe it'll be done before Christmas??
    I'll post pictures as soon as I figure out how.
    25k gallon, IG Vinyl diving pool, sand filter, auto cover
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: New Construction - Foiled by weather...again....and again....and again....
    Hi,
    Welcome to TFP.. ahhh the joys of having a swimming pool constructed in our yards ! ha! Don't worry though, it wil be woth it when springtime comes.
    Here is a tutorial on how to post unlimited pics.
    Posting Photo's Tutorial
    Enjoy!
    Divin Dave,
    Aug 2016
    Cameron, MO
    14
    Aug 2016
    Cameron, MO
    14
    Aug 2016
    Cameron, MO
    14
    And finally......during today's monsoon of a rainstorm......
    Aug 2016
    Cameron, MO
    14
    It is killing me that this pool is sitting there full of water. Water that hasn't been properly treated.
    I was able to get close enough this morning to get a sample of water. I ran a couple tests with my TF-100 came up with the following results.
    TC - 1
    PH - 8
    TA - 150
    CYA - 0
    I didn't bother testing for FC as I felt it wouldn't be high enough to even consider at this point. The builders did put several trichlor tablets in my chlorinator which I plan to remove as soon as I have better access to the pool. The TA and pH were a little surprising to me. I expected to be more acidic. I figure the trichlor will help lower the pH and raise CYA. At this point, it is better than nothing.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Its hard to tell, but I don't see an electrical bonding loop there, it should be a continuous copper wire going all the way around the pool and connected to the rebar, and going to a common bonding point at the equipment pad.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Yes, the trichlor will lower the PH a bit. Definitely leave the pucks in there for now to keep FC up and get some CYA in there.
    Aug 2016
    Cameron, MO
    14
    The bonding loop is there. You can barely make it out in the last picture. (The swampy one.)
    DFW, TX
    24,485
    Oh, yep, I see it. Good to have your swamp bonded!
    Aug 2016
    Cameron, MO
    14
    The long range forecast has no rain here from Sunday all through next week. PLEASE LET THAT HAPPEN!!
