Thread: Tahoe blue
    Sep 2016
    la mirada california
    Tahoe blue
    Our pool just got finish. We went with tahoe but Never in our wildest Dreams did we think our water color was going to be green. After reading a some post i found out that it starts green and then turns blue. How long does it take for it to turn blue. FYI its been 4 long days its got ten better but i still see the green.
    Mod Squad pooldv's Avatar
    DFW, TX
    Re: Tahoe blue
    Yes, tap water in a newly filled pool is fairly green. It usually clears up in less than a week.
    Nectarologist's Avatar
    Apr 2015
    New York
    Re: Tahoe blue
    Beautiful pool! Best of luck
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    Re: Tahoe blue
    I don't like Tahoe blue for that very reason. Mine is midnight blue and even it can look green on occasion.
    33K Pool/Spa, Pentair Equipment
    Davis Custom Construction - Home Page
