Na. Just put the CYA in the sock and hang it in front of the return. Some folks use a broom handle or a big rock. Just let it hang there and give it a good squeeze or two, every now and then.
This entire thread is why SWG's were invented. They add a tiny bit of chlorine continuously, so that there isn't a "raise and drop" of FC.
That said, the way you are doing it is perfectly fine as long as something doesn't go wrong (like a big pile of leaves or a small rodent get into your water). Oh, and if you have a lot of people in the pool, check the levels soon after they leave...just in case...
