Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Why daily bleach additions?
    Aug 2016
    Pace/FL
    49
    So here's a very newbie question. If CYA is a stabilizer it should maintain whatever the corresponding FC level is according to the CYA/chlorine chart, right? Why then the need to add anymore bleach at all?
    I know that this is a sill question but I just wanna make sure my thinking is correct. Even though CYA is a stabilizer the FC level will still diminish, just not as quickly, right? So daily bleach is still needed.
    22' Intex AG - 12K Gallons
    Model 633T Cartridge Pump
    August 17, 2016
    JoyfulNoise's Avatar
    May 2015
    13,257
    Re: Why daily bleach additions?
    In a pool with zero CYA, the FC has a half life of about 20mins or so. So, in about 2 hours, the FC is entirely depleted.
    In a pool with CYA, that half life can approach almost 8 hours (at high CYA). Therefore most of the FC will remain in the water.
    CYA is both a stabilizer AND a buffer for chlorine. It's buffering ability is what makes swimming in a (properly) chlorinated pool comfortable.
    Matt
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,024
    Hi,
    the question you asked is a good question, but it's not the easiest to answer without having a lot of knowledge about the actual chemistry. So, I have posted below a reply by Chem Geek on happens at the chemical level.
    Following that, a link to the thread so you can further look at what happens chemically if you wish to. But to start with, not 100% of the chlorine is bound by CYA.. As that unbound chlorine gets used up, the chlorine which is bound by CYA gets released....
    From Chem Geek
    It comes right down to chemical equilibrium between chlorine and CYA vs. chlorine bound to CYA where the equilibrium is shifted much more to chlorine bound to CYA at normal pool conditions. The chlorine bound to CYA has minimal activity in terms of oxidation and sanitation. Because this is a chemical equilibrium, as chlorine gets used up, more is released from that bound to CYA and this happens relatively quickly and in the time of the FC test which is why the FC test really measures reservoir chlorine (that is, chlorine that is bound to CYA as well as that which is unbound). However, actual chemical reaction rates, including the rate of killing pathogens or algae, is dependent only on the actual chemical species doing that killing which is hypochlorous acid (for oxidation reactions it is sometimes hypochlorite ion, but it is not chlorine bound to CYA)......
    You can read the whole post here. See No. 4.
    FC - Concept of
    Divin Dave,
    Aug 2016
    Pace/FL
    49
    So please tell me if the way I am currently maintaining my pool is okay. In the evening I bring my FC level up to about 5 or so. The next afternoon it usually has been reduced to 3.5, and so I add about 25 oz of bleach. I have only been checking my FC level every 2 or 3 days lately.
    I assume it's only normal for everyone to get used to their particular pool and know about how much Fc level is lost over a days time.
    August 17, 2016
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    You need to maintain your FC level in the recommended (target) range according to your CYA level, take a look at the link in my signature
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,024
    You should also keep an eye on your pH.
    I am assuming your keeping your target FC of 5 based upon the FC/CYA chart?
    As a person new to maintaining your pool by TFP method, we recommend you really should test FC daily. If you let the FC get too low (relative to the CYA level), then you are being a bit risky. I know that 1.5ppm loss in a day doesn't sound like all that much, but thats a 30% loss of FC in one day.
    And you are right, over time you will lean your pools apetite for chlorine and you can adjust your testing schedule. The only way to learn that though is by daily testing to start with.
    Divin Dave,
    Aug 2016
    Pace/FL
    49
    So what level should I bring it to every evening?
    August 17, 2016
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,262
    Based on your pool volume, add enough bleach to increase your levels about 2 ppm daily (This is what I do). Then, on a weekly basis, I test to determine how much FC is in the pool. If I am over, I make adjustments then (usually skip a day or so). Although, daily I check PH and FC with the Taylor K-1000 (presence of chlorine) only.
    If you add .5 ppm extra daily (because you burn off 1.5 ppm daily), by the end of the week, you will only be over by a little bit. Remember you loose a % and not a fixed amount daily.
    Another important note is to brush your walls frequently in your pool to minimize the possibility of algae growing on the floors and walls. Intex Pools do not have the same circulation as other pools and you could have some dead spots. Please make sure that your daily additions are not in the middle of the day when the sun is beating down on the pool. Add either real early or late as the sun is coming down and have the bleach mix for a few hours or so.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Aug 2016
    Pace/FL
    49
    5 is above my target FC. Yet I bring it to that every evening so that by the next day it will have drifted back down to around 3.5 - 4.0 and good for swimming. Am I doing wrong? My CYA was last at 30 so target is 4.
    August 17, 2016
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Any FC level, up to SLAM level for your CYA, is good for swimming. Target is what you want at all times. Letting it drop is asking for trouble. The minimum value is really only there so folks don't panic if they go a little below target.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Also, you say you add chlorine at night and you lose 1 or more ppm by the next morning? I may be wrong, but that seems like you are fighting something.
    Aug 2016
    Pace/FL
    49
    How is it possible to keep it at target level at all times if you only make 1 addition daily? I'm not "letting it drop". That's just going to happen automatically, right?
    No, I don't lose more an 1ppm at night. I just finished my first SLAM a week or so ago, and tested that.
    August 17, 2016
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    You would make your addition with your loss included. So you would shoot at 6, so when you lose 2 you're right at target.
    Aug 2016
    Pace/FL
    49
    Okay thanks. That's what I'm looking for. Thanks for being so patient with me.
    August 17, 2016
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,024
    see answers in red.
    Quote Originally Posted by fralo View Post
    How is it possible to keep it at target level at all times if you only make 1 addition daily? You can't keep it at target level at all times without an automated system to provide chlorine to the pool. But you can keep it from falling below the minimum level per the FC/CYA chlorine chart. You will have to add chlorine every day to keep it within the recommended minimum and target levels.
    I'm not "letting it drop". That's just going to happen automatically, right? Yes. Chlorine is burned off by UV from the sun and from stuff that gets in the pool, like leaves, grass, bugs and other stuff. If you don't replenish it daily, it will go all the way down to zero in a couple or 3 days. The CYA just slows it down a bit. Without CYA you would loose all of your FC in 1 day.
    Divin Dave,
    wjr75's Avatar
    Jun 2013
    IL
    836
    If you are getting full sun in FL you may want to bring your CYA up higher to maybe around 45ppm and keep your FC target at around 7ppm. That's what I do up here in IL which doesn't get your sun and I also have an auto cover. If I don't use my pool with the cover during the week I don't need to add chlorine for 3 days.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Don't forget, there really isn't a 5 for CYA. The scale isn't linear, so just round up to nearest 10. I like the idea of adding to a number, then 'glance' to see if the dot is gone.
    Aug 2016
    Pace/FL
    49
    If I raise my CYA up to about 50 will the higher target FC make it a little more uncomfortable on my eyes?
    August 17, 2016
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    No. The ratio holds and the actual amount of un-bound chlorine is the same. Mostly I read about pH having a greater effect on eye discomfort than FC.
  20. Back To Top    #20
    Aug 2016
    Pace/FL
    49
    I plan on upping my CYA. How do you do it with a sock? Do you actually cover the return and secure it with a rubber band or something?
    August 17, 2016
