Thread: Poolmaster testing kit vs TAylor
    May 2015
    Fullerton, CA
    639
    Just for kicks i tried the poolmaster kit the PB gave us. Ph was off and no color really matched, guessing it was closer to 7.6, but 7.4 and 7.8 looked miles away? The ta result was 100ppm, my taylor kit show 70ppm. Scary.
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    JoyfulNoise's Avatar
    May 2015
    13,264
    One problem with the PoolMaster kit is that they have you adding thiosulfate chlorine neutralizer before adding the pH reagent. Thiosulfate chlorine neutralization is NOT a pH neutral chemical reaction. So the pH results from that kit are quite likely off.
    Taylor actually blends different types of chlorine neutralizers to produce a net-zero pH reaction. The results from the Taylor reagents are far more reliable in that sense.
    Matt
    May 2015
    Fullerton, CA
    639
    Re: Poolmaster testing kit vs TAylor
    30 ppm difference on the TA test is just nuts! That free kit needs to go into the trash.
