Page 1 of 3 123 LastLast
Results 1 to 20 of 51
Thread: Algae and/or other bacteria won't die
    Sep 2016
    Magnolia, TX
    38
    I've read through the process of slamming, brushing, balancing everything, etc... I can't seem to get rid of this issue, though.
    First off the pool is and always has been crystal clear and all the chems have been correct except the chlorine has been kept on the low side due to lack of knowledge and not having the fas-dpd test until about 4 days ago. I started noticing what looked like dirt or what I thought was dead algae. I figured out it wasn't dirt or dead algae, it was very much alive and well mustard algae. It seems to all come from under the wedding cake steps where there was quite the algae bloom. I put 32oz of algaecide in but that didn't work either.
    I removed and cleaned the steps then put them back in, I brush the pool and vacuum it everyday, I remove and spray off the filter everyday, monitor the chems constantly and I don't know what else to do. I've been holding the FC at 25ppm+ for 5 days. How long is this process supposed to take? It dropped 3 ppm last night which is way better than before but during the day it drops 1.5 an hour. When it was running correctly it dropped 2-2.5 per day. It gets direct sun all day long.
    Here are some details on the pool and chem levels
    Using the taylor 2006 kit
    AG 24x15 oval 10,000 gallon vinyl
    FC= been holding it at 25-30 for 5 days
    CC= .5
    PH= 7.2
    TA= 50
    CH= 180
    CYA= 45
    If you need more details please ask. This is driving me nuts
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Algae and/or other bacteria won't die
    I suspect part of the problem is the algaecide you used, there is a reason it is NOT listed as part of the SLAM process, depending on the type of algaecide you used it can confuse the process and cause chlorine consumption and or CC's to be shown on the test. The same goes for various yellow out mustard algae products. The reason we don't include them in the process is not only that they are not needed, but that they can actually make this harder by confusing the test results.
    Sep 2016
    Magnolia, TX
    38
    Quote Originally Posted by Isaac-1 View Post
    Cool, so now what?
    Sep 2016
    Magnolia, TX
    38
    Quote Originally Posted by klynne View Post
    add 5 lb of alkalinity increase filter 4 hours add 1 lb of ph increase filter another 4 hours or longer then shock your pool Meaning if the 8 hours puts you in the middle of the day or night wait till evening to shock pool Your water is out of balance chemicals work better in a balanced pool
    No. I have a vinyl pool. PH climbs too quickly with a higher TA. Thanks for trying, though!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I would suggest continuing SLAM level and do the overnight chlorine loss test again to confirm the algae / algaecide has burned off
    p.s remember that pH test is not valid when FC is over 10 ppm
    Sep 2016
    Magnolia, TX
    38
    Roger that, ph is not my concern.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    4,965
    Hang in there and don't give up or get frustrated! You're doing great! It took a while longer than you might imagine for the algae to show up, and it will take a little while to rid yourself of it.
    Divin Dave,
    Sep 2016
    Magnolia, TX
    38
    Water is still clear. Hopefully the algae is almost dead and I can stop the slam soon.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,428
    I don't really have anything to add, other than to keep up what you are doing. If the pool is not in use, you might remove the steps altogether just to eliminate that as a possible haven for algae.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Sep 2016
    Magnolia, TX
    38
    Quote Originally Posted by jeffchap View Post
    Thanks for the reply! The pool would be in use but the algae and high chlorine is preventing that at the moment. We might switch to a ladder if necessary.
    Dec 2015
    Hawera, Taranaki, New Zealand
    443
    You have been having little feedback because you seem to be doing all the right things.
    You should notice your overnight loss to continue to fall and then one day you will pass, prob in the next few days
    Only thing I could suggest is have you checked your skimmer, there may be a bit of algae hiding out there
    There is no problem with swimming if you meet the following three:
    You can see a swimmer on the bottom of the pool - check
    Your ph is between 7.2 and 7.8 - check
    Your FC is above minumum and below slam
    So let your FC fall to 1ppm beneath your slam level, swim away and bump the FC up after your swim
    6000 gal, AG vinyl, Intex ultra frame 16ft, 1200 Gallon Sand Filter, DIY Solar, Clear Choice Labs Testing Kit
    Sep 2016
    Magnolia, TX
    38
    If I upload a video does anyone think they can tell what this stuff is that keeps coming back? I passed SLAM for two nights in a row and dropped down to normal levels in a day and a half( I went from 30 ppm FC to 6.4) but now that stuff is back on the floor.
    30,282
    A pic or video is just fine. Having said that, I believe the answer will be dead algae.
    Sep 2016
    Magnolia, TX
    38
    Is it normal for FC to fall that fast? The pool is in full TX sun all day, btw
    Sep 2016
    Magnolia, TX
    38
    Here's the video and a question........
    Just got in the pool for the first time since the SLAM. The entire cove(perimeter) Feels like sandpaper and appears to be ruined. Any ideas what happened?
    https://www.youtube.com/watch?v=1f6SDspIs8Y
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    340
    A lot of that looks like simple dirt, though dead algae can look that way. Do the dark spots "poof" up and disappear when you touch them? The steps look good on the inside, don't know about under the bottom. As far as the liner being "ruined" that is hard to determine from here. Your FC level hasn't been that high for an abnormal length of time. Is it bleached as well? How about adding your detailed info to your signature:Pool School - Getting Started so we will have a reference to what you have. At least the water is clear and the rest of your chemistry is in line. You stated that your CYA is 45...typically that would be 50 - always rounded up. Brush it frequently to keep any live clusters broken up so the chlorine can get to them. As soon as they solidify they create a film to protect them from the chlorine. You're on the way....just keep going!
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 2hp Pentair pump.
    Sep 2016
    Magnolia, TX
    38
    Quote Originally Posted by Vickery View Post
    Yes, the dark spots poof up and disappear.
    As far as the liner, it doesn't look bleached but I think it has been damaged by pouring the bleach around the perimeter. I've never done that until the slam because I figured it would help get the bleach where the return doesn't reach. I normally just pour it into the skimmer basket and never had a problem.
    So I guess the bleach settled and it basically blistered up.
    Is that something that would happen? It's the only thing that I can think of.
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    562
    Quote Originally Posted by xcrazydx View Post
    I don't know if that could happen or not. Never heard of it happening anyway, but I''m no expert. Are you using a brush for vinyl pools and not one with sharp metal bristles?
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    30,282
    Did you have the pump running when you added the bleach?
    When did you last vacuum?
    When did you last brush?
    If you have an auto vac, when did you last run it.
    The video tells me it may have been a while. you are certainly not ready to finish the SLAM. I saw lots of live algae in your video.
  20. Back To Top    #20
    Sep 2016
    Magnolia, TX
    38
    Quote Originally Posted by mickey4paws View Post
    Soft bristle
