Thread: test - link code
    Teald024's Avatar
    Aug 2016
    Columbus, Ohio
    1,294
    test - link code
    testing
    To post a straight link with linked text the code:
    Pool
    Code is : <URL="https://notalwaysright.com/tag/pool"> Pool</url> replace < & > with [ & ]
    To post a straight link without linked text the code:
    Code is : <url>https://notalwaysright.com/tag/pool</url> replace < & > with [ & ] make sure it is not automatically linked in msg field before submitting
    <img> www.xxxxx.comz</img> replace < & > with [ & ]
    Get the smaller version of an image on Imgur:
    info from here
    If you want to show an image on the forum from imgur.com but the image is too large in size, you might want to only show a smaller version of the original image. By default, the image dimension the image is served as is the full resolution. To reduce this to a large thumbnail, simply add a suffix to the image name.
    So if you image URL is https://i.imgur.com/xxxxxxx.jpg, you simply add the suffix to the image name: https://i.imgur.com/xxxxxxxS.jpg. Now your image is show at a smaller size on the forum
    Suffixes with the dimensions and letters to choose from:
    •s = Small Square (9090)
    •b = Big Square (160160)
    •t = Small Thumbnail (160160)
    •m = Medium Thumbnail (320320)
    •l = Large Thumbnail (640640)
    •h = Huge Thumbnail (10241024)
    Dave - Aqua Leader Elegance AGP 15'x30'x 54", 12k gallons, vinyl liner ... Hayward/SwimPro Voyager pump SW159412STL, 2hp, 2spd, Hayward/Voyager 175sf element filter SW175MDDVPAKS, Installed August 2016 ... Liquid Chlorine, Stenner, Woods 50015 timer ... TF-100 .... CYA/Chlorine Chart ... Recommended Levels ... Basic Care Schedule ... Extended-Test-Kit-Directions ... ABCs of Pool Water Chemistry
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,366
    Re: test - link code
    First link worked for me and I enjoyed a few stories!
    Second link didn't work for me in Chrome or Edge
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Teald024's Avatar
    Aug 2016
    Columbus, Ohio
    1,294
    fixed it. fat finger error
