Thread: Buy from The Pool Factory?
    Sep 2016
    Watkins Glen, NY
    6
    I hope this is an ok part of the forum to post in. We are looking at getting a pool for next summer and are wondering about ordering online from the pool factory. We want a 12ft round, semi inground pool with a saltwater system and our local stores don't have an 12ft option for semi-in ground, 16 is the lowest. I found one over at the pool factory for about $1,500 vs the $9,500 our local store quoted for their 16ft one. That's before install. Is the pool factory a reputable site? Is it fine to order a pool online and get someone to install it? Our other local store told me they don't do saltwater in above ground pools because it destroys them, but I don't think I believe that.
    Any and all advice for a first time buyer is welcome! Thanks
    dsmith99's Avatar
    Jun 2016
    SW, Iowa
    222
    Re: Buy from The Pool Factory?
    I bought my pool from them this spring, I'm very happy with the pool and they had stellar customer service. A damaged top rail was reported on Memorial day and I received a replacement the very next morning at 9am. The pool is as good of quality as any other I've seen. I had planned to make mine saltwater so I bought the saltwater LX model. It has all resin upper and lower parts and coated steel walls and posts that should stand up to salt water. Currently I just use liquid chlorine (TFP methodology) and will probably keep it that way as it has worked very well. After the pool, new vinyl privacy fence and a deck I felt like I did not want to spend another thousand to add a SWG. Late in the summer I did finally add a dosing pump and 15 gal bulk storage tank to automate chlorine delivery and it has worked out great. My pool is buried about 12" but was allowed up to 27". I have to admit I was a little concerned about salt water damage too. Some friends have an 18' Intex pool that is salt and after about 7 seasons the frame is showing a lot of rust.
    AGP 24' x 54" approx 14000 gal Full sun all day, Hayward 1.5 HP and EC50 D.E. filter
    Stenner 45MPHP10 10 gal/day fixed rate with intermatic ET1125C timer
    Dolphin E10 robotic cleaner, 330 gallon Tiger River Spa, Taylor K-2006C test kit
    Eustis, Florida
    68
    I wouldn't hesitate to buy a pool from them. Just curious, are you wanting a small pool due to limited space?
    AGP 33' x 54" Lomart Verona, Approx. 27,300 gallons, Pentair cartridge filter/pump 2-speed, 1.5 hp, Dolphin Escape robotic cleaner.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Hi Hogwaffle,
    just a note on the SWG thing.... dont believe everything you hear from pool salesmen. There are plenty of pools now days that are designed to stand up to SW better than others. So, be aware that if you want SWG, to get the coated ones as mentioned above, and you'll be just fine.
    Divin Dave,
    Sep 2016
    Watkins Glen, NY
    6
    Thanks everyone. I figured they were good, but always good to hear it from people who are familiar with them. Yes, small pool because of space. We have 2 yards and want to put the pool in the generally unused small one and deck around it I would love one 14 feet, a 15 foot one would be okay, but either of those only leave about 3 ft of space around for decking. I'm looking at the 12'x54" Saltwater 8000 Round Pool, but if anyone has any recommendations I would love it. Also recommendations on the SWG. I basically ignored the local guy who said you couldn't do saltwater, they are for sure an old school sort of store. I've read that they take less upkeep so if that is true I'm game for spending the money. If the chemicals aren't too hard to work with, maybe I will stick with that. Any thoughts on one system vs the other?
