Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: SWG panel lights question/repair
    Sep 2015
    owasso, ok
    38
    Hello--I have the blinking "no flow" light then it moves to a green "generating" light then the lights go out altogether. I have been reading about replacing the current limiter. I think I can do this.
    My question is....I noticed the LCD panel is still showing numbers, is this normal if the limiter is bad?
    Could it be the flow switch? How is the flow switch removed to replace? I cant seem to find how to get it off the salt cell.
    Thanks for any advice. Much appreciated.
    Hayward Aqua Rite Salt pool
    Dolphin cleaner/PoolCleaner
    Pentair Triton II filter
    Heater
    approx. 24000 gallons
    Aug 2013
    Oklahoma City, OK
    127
    Re: SWG panel lights question/repair
    What numbers is it showing exactly? What is the voltage? Should be between 30-35.
    20000 Gallon, Sand Filter, IG Plaster, Hayward Aqua Rite 40k SWG, TF-100 Test Kit, Taylor SpeedStir
    Sep 2015
    owasso, ok
    38
    Im at work, Ill provide that when I get home although I was just curious if there should be power to the LCD screen at all. Thank you! I don't know know much about electronics at all but I am willing to learn and even more motivated to save money
    Heater
    Jul 2014
    Hope Mills, NC
    561
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Aug 2013
    Oklahoma City, OK
    127
    Yes there is still power to the LCD. Follow the link from the poster above it really isn't that hard. Go get a cheap solder iron from harbor freight you shouldn't need anything more than that to complete the job.
    Sep 2015
    owasso, ok
    38
    Quote Originally Posted by Tanner M View Post
    OMG this is FANTASTIC! We have had a LOT of lightning lately and the biggest earthquake Oklahoma has ever seen last week. I want to blame it on THAT lol. Thanks!
    Heater
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,853
    When replacing the varesistor I found it is much easier if you don't even try soldering to the board. I just clipped the old one off leaving the legs in place and wrapped them around the legs of the new one. Soldered the connection, clipped off the excess. It left the new part setting away from the board at a 90 degree angle. Easier process and provides better cooling. Just be sure to space it so that it doesn't come in contact with the case or other components. If that is your problem, it's a $2.50 part and will take about a half hour total time to fix.
    chiefwej
    Sep 2015
    owasso, ok
    38
    Chief, we will try that. I hope I ordered the right part. Do you think that the age of the panel changes the part? I ordered form Digi-key 570-1062-ND. My system is about 7-8 yrs old.
    Heater
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,853
    My system is closer to 10 years old and that's the part I used. I'm pretty sure they used the same one up until a couple years ago when they redesigned to eliminate the problem.
    chiefwej
    Sep 2015
    owasso, ok
    38
    Thanks Chief. One more question as Im waiting for the part to arrive......the LCD panel looks like its still working....is the salt content displayed still accurate or not? I have been throwing in chlorine but I don't have any salt testing ability.
    Heater
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,853
    I wouldn't trust any of the readings until you to working properly. BTW The salt readings become inaccurate as the cell ages. They show salt levels lower than the actual. I found this the hard way, adding salt and adding more, until I figured out that the cell was going. When I replaced the cell I found the salt was so high that I had to drain several thousand gallons to get back down to the correct salt level.
    chiefwej
    Jul 2014
    Hope Mills, NC
    561
    The salt isn't going anywhere unless you drain water.
    Don't forget to reset the display after you fix the current limiter or your values will really look off!
    Vinyl in-ground
    1 HP Pump
    Hayward SWG
    Sep 2015
    owasso, ok
    38
    Good advice......so do you guys trust Leslies doing the cell check to see if its still good or is there another way to check?
    Heater
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,853
    You can compare the chlorine reading in the pool to that right at the return. The water returning through the SWG should be much higher FC level if it's working. Just be sure it's set on 100% output when testing. That of course only shows if it's working or not, doesn't show it's slowly failing which is common.
    But if Leslies says it's okay, I'll bet it's okay, since they have a vested interest in selling a new one.
    chiefwej
    The Aquarite is easy to diagnose. They give you the information you need. If the amps and volts are good, it's definitely making the correct amount of chlorine. If the instant salt reading is consistently accurate, the cell is good. It's that easy.
    Sep 2015
    owasso, ok
    38
    Well, we were unable to get the old component off the board, so we took it in to a computer wholesale store, where they are going to do this for me for 35.00. I pick it up today, fingers crossed.
    Heater
    Sep 2015
    owasso, ok
    38
    Well, picked up the panel and re-installed. No power and so dissapointed. Any ideas of things to check? I have checked and double checked all my connections and everything looks good.
    Heater
    What are the diagnostic readings?
    Sep 2015
    owasso, ok
    38
    The LCD is not coming on so I don't know!
    Heater
  20. Back To Top    #20
    Google this: Aqua Rite & Aqua Rite XL Diagnostics Manual
    Can you post a picture of the board?
