Results 1 to 9 of 9
Thread: errors adding photos from flickr
    Jun 2016
    FL
    901
    hi, when i go to add photos to TFP forum threads, i am getting the following message: "Error: Invalid File". But when i uncheck the "Retrieve remote file and reference locally" box, then i can add the photo. But when I add the photo that way, other users on Tapatalk cant see my photos. Any idea what i am doing wrong?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: errors adding photos from flickr
    I'm not sure about how to on Flickr but this link discusses Flickr, Posting Photo's Tutorial
    Jun 2016
    FL
    901
    Quote Originally Posted by pooldv View Post
    Thanks, these are the instructions I have been following. Oddly, it worked no problem when I first started doing it a couple of weeks ago. Just recently I get that invalid file error. I have what seems to be a bypass solution: Uncheck the "Retrieve remote file and reference locally" box, add the photo, then remove all of the text before and after the photo in the post. I dont mind doing it this way, but wanted to make sure it wasnt a forum issue.
    JoyfulNoise's Avatar
    May 2015
    13,226
    Flickr doesn't have a IMG code box somewhere that you can copy & paste from?
    Matt
    Jan 2012
    'burbs of Augusta, Georgia
    7,359
    I prefer to use Tinypic as you don't have to have an account to use it. TinyPic - Free Image Hosting, Photo Sharing Video Hosting
    Jun 2016
    FL
    901
    It has a BBCode but not IMG code, unless it is somewhere I can't find.
    Brian - UNDER CONSTRUCTION: 17K gal SW Gunite IG. 17'x23'(w/shelf)x34'. 650sf. 114' perim. 3.5'-5' depth sports pool. 7'x11' sun shelf, 6'x8' spa. Intelliflow VSP, IC60 SWCG, CC420 filter, 4 LEDs (2 Globrite and 2 Intellibrite). Hayward 140K BTU heat pump. Pentair EasyTouch 8 automation. Ivory travertine deck. 8"X16" travertine coping. NPT lightwaves Aquamarine spa tile and marker tiles. Undecided on plaster/pebble finish.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,095
    Copy and paste the BB code. This has the "IMG" code already inserted into it along with a link that if you click on the photo takes the user to your account to view more of your shared photos.
    Jun 2016
    FL
    901
    Quote Originally Posted by Leebo View Post
    Yes this is what I have been doing. It gives me the error I mentioned and cannot be viewed from tapatalk users.
    Jul 2011
    Eastern Ohio
    7,095
    What happens when you just copy/paste the BB code right into the post without using the Insert Image "photo frame" icon??
