Thread: New Pool - New Taylor Test Kit!!
    May 2016
    Oshawa, Ontario, Canada
    26
    My pool was bulit/opened in July - been flying blind since today. Just received my Taylor 2006 kit today, so excited for it, better late than never!! Pool looks great, nice and clear. We probably have about 3 more weeks in the season before it is closed, so i don't expect much tweaking, but wondering what you think of the numbers.
    First set of test results.
    FC - 12.5
    CC - 0.5 - Although when the sample sat for maybe 1 minute, it turned back to a light shade of pink, is that normal??
    CYA - 90 - I know this is high, but considering an FC of 12.5....still ok. I'll fix this after the winter.
    PH - 7.6 - 7.8
    CA - 150 - The sample turned more of a pink than a red and then more of a purple than blue - normal??
    TA - 150
    When the pool first was filled I added stabilizer and used sticks in the chlorinater, hence the high CYA. Been using only liquid chlorine for the last 4 weeks, guessing on quantity as I had no real test kit until now.
    Temp is about 80 during the day then turned up to 88 for the evening, solar blanket is on all day at this point.
    Comments welcome.
    New Pool Build July 2016
    Taormina In Ground (steel/Liner) 17,100 Gallons. 16x20x32
    Hayward SP3200VSP 1.8THP Pump
    Hayward Pro Series Sand Filter S-220T
    Hayward Chlorine Feeder CL200EF
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: New Pool - New Taylor Test Kit!!
    Just remember the pH test is not valid when your FC is over 10 ppm
    May 2016
    26
    Does the Ph typically read high or low under these circumstances, it is it just outright not valid.
    What about the other results?
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    883
    Well done on getting a good test kit.
    Generally it tends to read high. You have a bit of room to manoeuvre so that you can drop your FC just below 10 to get a reliable reading on the pH when needed.
    Yes it is normal to go back to pink when you leave it to sit.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
