Thread: Min temp for chlorine production
    Jun 2015
    Ottawa/Ontario
    340
    Is 70 a ballpark number, below which no more chlorine is produced - hoping to last another two weeks but am getting lazy with my solar cover given swim season is over for us! I figure at the end of these next two weeks, water will be closer to 60! Or should I should I just start dumping the bleach in now and give the generator a break?
    Thanks all!
    Tom
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Re: Min temp for chlorine production
    From what I've seen on my SWG it keep generating down to 50. Around there, it gives a low temp error.
    OOPS! around 60 is the correct number!!
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    JoyfulNoise's Avatar
    May 2015
    13,226
    What make and model do you have? They are all slightly different but I know my Pentair IntelliChlor throws a cold-water cutoff error at around 58F. Some are spec'd to shut off around 60-62F. It depends, but 60F is generally around the average. It's ok to use all the way down to the cold water cutoff so I would just keep using it until it refuses to generate, then switch to bleach. FC loss rates are so low below 70F that you could probably go a few days without noticing the generator isn't working.
    Matt
    Jun 2015
    Ottawa/Ontario
    340
    Awesome. Thanks all. Hit 70 this am. Keeping my eye on the FC level - so far so good! Cheers. Tom
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    Jun 2015
    Ottawa/Ontario
    340
    Aquarite T-15
    May 2015
    13,226
    The Aquarite systems will generate down to 50F.
    Matt
