Thread: 2-speed Hayward Tristar - won't start on high
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Hi TFP,
    My motor is acting strange. It will not start on high speed - it will hum/buzz for about 1 second, then stop and wait a minute, buzz, stop.....etc. It will start just fine on low, and once running it will happily switch between high and low. For the time being, I have it set such that it starts on low and later switches to high for cleaning, so I don't think it's a crisis yet.
    I've read enough stories on here to suspect that it is related to a switch or capacitor, but would appreciate any help in starting that troubleshooting process. Thanks!
    mas985's Avatar
    Pleasanton, CA
    11,765
    Re: 2-speed Hayward Tristar - won't start on high
    Sounds like it might have something to do with the centrifugal switch. That controls how the motor starts. Check the contacts for corrosion.
    Mark
    Oct 2009
    3,899
    OK, I popped open the back over the weekend. I cleaned the contacts at the end of the copper strips (I think these are the right ones?), but that didn't make a difference; it still makes an angry buzzing sound when I try to start it on high.
    The motor does have two capacitors, one under the backplate and one hump on top. Is there anything else I can check before I just take the motor into a shop?
    mas985's Avatar
    Pleasanton, CA
    11,765
    I would check the start capacitor next using a multimeter.
    Mark
