Thread: Gas heater life expectancy
    Oct 2014
    Villa Park, CA
    52
    What’s the range of useful life for a gas pool heater? What are the usual reasons they are replaced? I'm in sunny SoCal so it's hardly used and enclosure rust-out isn't an issue.
    20' x 40' 30,000 gallon IG Plaster with Spa, wading pool, fountain built 1993
    Pentair 011018 IntelliFlo / 2HP fountain pump / 2 HP spa jet punp / Jandy Ji8000 controller with IntelliComm II interface to IntelliFlo
    Crystal Water Aqua Clean 60 Sq ft DE filter / FlowVis Flow / Stenner DIY Chlorinator / The Poolcleaner 4-wheel / Taylor K-2006
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Gas heater life expectancy
    7-10 years these days. The older units would last closer to 15.
    Rusted out, leaking heat exchanger, or just needs too many repair$.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
