Results 1 to 7 of 7
Thread: Getting ready to close
    May 2016
    Woodbridge, VA
    97
    I wanted to ask quickly as I was reading through the Above Ground Pool Closing article in PoolSchool it suggested using a polyquat algaecide. Can someone point me to actual brand names or products that I should look for either online through Amazon or at Leslie's? I'm sure online would be cheaper. TIA.
    Kayak 12' x 24' 8600 gallon pool; Vinyl liner; Intex Sand Filter 2800 GPH; TF-100
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: Getting ready to close
    I think it's just Polyquat 60.
    Jun 2014
    15,189
    Just make sure the product you are considering buying actually lists the ingredient as "Poly{oxyethylene(dimethyliminio)Ethylene (dimethyliminio)ethylene dichloride}". That's a mouthful I know. Numerous places sell stuff online without listing the ingredients, so be careful and ensure you're getting the right stuff (ingredient). People have obtained Polyquat 60 at Pool Stores, on-line, Home Depot, even Wal-Mart. Amazon should have it for just about $20. You might also check with InyoPools.com and tell them you're from TFP.
    May 2016
    Woodbridge, VA
    97
    Quote Originally Posted by Texas Splash View Post
    Thanks so much TS.
    Sep 2015
    Rome, NY
    363
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
    Aug 2014
    Northern IL
    4,615
    Also, it is very early to close in your area of VA. We strongly recommending waiting to close until the pool water temps are below 60 degrees. We also recommend opening before they reach 60. I assume you read that part, but wanting to make sure...
