Results 1 to 8 of 8
Thread: Safety Cover selection help
    Jun 2014
    Philly, PA
    44
    Hi All,
    I've finally got my pool rehab and ready to go but now it is time close the pool down in a few weeks. I have been looking at safety covers and I wanted to go with a solid cover with no drains. I wanted to get a loop loc cover but they don't sell directly to consumers and a quote I got from a pool guy seems kinda high. I was going to get a quote from leslies pools but I heard horror stories about them and the guy said the best cover they have is made by GLI. Should I consider installing the pool cover myself or does the cost provided so far seem reasonable for my size pool? No special features except a diving board.
    The quotes I got from my pool guy is including installation. My pool is a kidney shaped pool roughly 512sq ft.
    Loop loc
    Ultra-Loc solid with drain panels - $3535
    Ultra-Loc solid with no drain panels - $3745
    Loop-Loc Mesh - $3995
    Merlin
    SmartMesh - $3775
    Dura-Mesh - $3050
    Solid XLS with pump - $3875
    25k gal inground pool, concrete, Filter Jandy Dev48, Anthony pool pump
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Re: Safety Cover selection help
    Our loop loc mesh was $5700 installed. I recommend the mesh.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Our cover pricing was very much inline with your pricing in the mid-upper $3K's IIRC. We have Merlin Smartmesh. No reason to go with Duramesh - get the best mesh you can get. I also see no need to get a solid cover. Loop-Loc mesh would be equivalent to Smartmesh I suspect. You could install, but eh, I'm over saving a few hundred dollars to have it done quick and right in many cases. I'm ok with letting someone make a few bucks from time to time. Still a DIY'er at heart though.
    Scroll down a few posts on the page below to see ours. I think our tan looks sharp.
    http://www.troublefreepool.com/threa...altimore/page6
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jun 2014
    Philly, PA
    44
    Thanks for the suggestions. Any reason why you both suggest mesh over the solid? I have about 50 trees around my property and pool so you can imagine the leaf fall and debris in the fall. I would rather open a clear pool and spend less time and cost on cleaning debris off the pool floor after opening.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Nothing will physically get through either except water. The only issue is if you would have leaves accumulate on the mesh cover when it gets covered in snow which would then allow the cover to drop to the water level and the leaves could steep in the pool water. If you think the leaves will blow off to the decking or landscape areas, which they probably will, then no worries. Mesh covers are much lighter and easier (not easy just we easier) to handle. We don't get a lot of leaves but none ever stay on the cover itself after a breeze.
    You won't open to a green pool if you close late and open early, so close after the water drops below 60 degrees and open before it reaches 60 degrees. Below that algae doesn't really grow.
    Jun 2014
    Philly, PA
    44
    Thanks for the info. I have 3 other pool companies coming out this week for their quotes. I'm getting quotes on anchor, Leslie pools and a quote from an authorized loop loc dealer.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    You should have well rounded quotes to choose from.
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Quote Originally Posted by Imxelite View Post
    If you are in the Philly area you'll prob get the same Loop Loc guy as me. Nice guy. They did a good job installing.
    Test Kits:
    My Pool:
