Thread: What are the precipitates during TA test?
    Ronald U.'s Avatar
    May 2015
    Pearland, Texas (near Houston)
    88
    Just curious about the chemistry. Usually once I begin to add R-0009 I notice some stringy precipitates form. What are those, exactly? Thank you.
    In-ground gunnite, 24k gal., Hayward DE filter, bleach, borate, Hayward Tiger Shark robotic cleaner, 75% full sun
    JoyfulNoise's Avatar
    May 2015
    13,207
    Re: What are the precipitates during TA test?
    I have never seen that before. The R-0009 is simply sulfuric acid that consumes alkalinity and eventually shifts the pH of the sample below 4.5 which is the green/red transition point.
    Is your R-0008 indicator dye old? It can go bad with age, get clumpy and start clinging to the inside of the dropper bottle.
    Other than a possibly compromised indicator reagent, I have never seen what you describe.
    Matt
