Thread: Vacuuming Debris
    Vacuuming Debris
    Been trying to vacuum the dead algae to waste. its taking forever. The pool is clear just need to get rid of the fine particles in the deep end. Anything I can do to speed it up?
    IG 15000gal Liner. Hayward DE 75. 1.5hp Jacuzzi Magnum single speed. Oval pool built in 1985. Buffalo, New York.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    Re: Vacuuming Debris
    Hi Sandy31,
    Can you please put your location (city and state) in your profile? Pool School - Getting Started
    Can you post up a full set of test results and what test kit you used to get those results? Use this format:
    FC
    CC
    PH
    TA
    CH
    CYA
    We recommend the TF-100 as it is the best value: Pool School - Test Kits Compared
    The presence of dead or live algae means you need to SLAM Pool School - SLAM - Shock Level And Maintain
    SLAM until you meet all 3 criteria:
    CC is 0.5 or lower;
    You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
    And the water is clear.
    The presence of dead algae means that the water is not clear and you need to continue your SLAM.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    The water is clear and I can the see the bottom just its filled with fine dust about 3 inches thick in some spots. When I try to manually vacuum it. It starts to stir up and I have to wait till it clears.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    Again, the "fine dust" you have is algae and you can't get rid of algae unless you SLAM. You probably have just enough FC to keep it from becoming an ugly green swamp, but not enough to kill the algae. DE filters clog very quickly with algae that is probably helping you from getting worse, but I image that you are having to backwash more frequently than usual.
    You really need to SLAM your pool to get ahead of the algae. With a DE filter, this will go quickly, but you will need one of the recommended test kits.
    Post up some results when you have them and we'll help you get this thing cleared in no time.
    Karen
