Page 1 of 8 1234 ... LastLast
Results 1 to 20 of 158
Thread: Clueless Newbie
    Sep 2016
    Clover, SC
    128
    Clueless Newbie
    Having a heck of a time getting our pool clear. We bought the home on 8/17 I never had a pool, my husband did when he was a kid but his Dad and older brothers took care of the chemical part.
    We had the filter hose pop off of the pump the first week and lost a lot of water. Put more water in using the hose (made the big mistake of leaving the hose in the water overnight, not realizing that it will just syphon right back out once the water was shut off) We thought we had a leak and water is EXTREMELY expensive here so we did not refill again. We did not put any chemicals in the pool for at least 4 days, we wanted to find the leak that we thought we had. The old owner of the home came over and was trying to help us find the leak and then he asked about the hose... ta da we found the socalled leak! Anywho... now we can not for the life of us get it clear. I went to the pool store and they had me get low and slow to bring down the ph and burn out 73.
    3.5 cups of low and slow for 6 days, 1st day 2 cups of algaecide and 3 bags of burn out and then 2 more bags the next day... got nice and clear. We then proceeded to vacuum all the sediment that settled on the bottom. After vacuuming, backwashing and rinsing, the filter blew in cloudy. So now we are cloudy and a tinge of green again!! Very frustrating
    Need a recommendation for a testing kit and some advice to get this bad boy cleared up. Right now all we have is what the prior owner left us and they are those test strips, they don't seem to be very helpful.
    24' round above ground - 13,500 gal
    sand filter - TF-100 - 1.5 hp pump
    We live outside of city limits and water costs are doubled
    Jan 2012
    'burbs of Augusta, Georgia
    7,693
    Re: Clueless Newbie
    Staci- I'll give you the Cliffs Notes of TFP care-
    1) Order the TF-100 or Taylor K-2006 test kit from TFTestkits.net They ship from NC so it would be pretty fast to you in Clover.
    2) Stay out of the Pool Store. All they will do is sell you expensive versions of basic chemicals, or worse- chemicals you don't need such as that algaecide.
    3) Go stock up on basic, plain 8.25% bleach from Walmart .... about 10 gallons to start.
    Start reading: ABCs of Pool Water Chemistry and more to the point this one --> SLAM
    When your test kit comes in get back to us with the following results:
    FC
    CC
    pH
    TA
    CH
    CYA
    We'll be waiting to hear from you We'll get this cleared up! I swear!
    Yip
    Jun 2014
    15,895
    Re: Clueless Newbie
    Welcome to TFP Staci!
    Sep 2016
    Clover, SC
    128
    Re: Clueless Newbie
    thanks...
    Sep 2016
    Clover, SC
    128
    Re: Clueless Newbie
    should I do anything in the meantime? My husband is going to pick up a 5 way test kit from Home Depot... will that tell us the readings we need? The kits from testkit are a little on the steep side for us right now.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Clueless Newbie
    The TF-100 will pay for itself if chemical savings alone within the first season, not to mention the frustration you will have with lesser test kits. Having said that really the only two test kits on the market that will let you manage your pool the way we teach are the Taylor K-2006 and the TF Testkits TF-100, the K-2006 is a little cheaper but will cost more in the long run as it has far less reagents included for the critical FAS-DPD chlorine test and the CYA test. Given you have an algae problem I would strongly suggest the TF-100 with the XL option which doubles the amount of FAS-DPD chlorine test reagents.
    p.s. if it is the 5 way drop test it can be minimally useful, if it is the 5 way test strips you are better off using a Ouiji Board
    Sep 2016
    Clover, SC
    128
    Re: Clueless Newbie
    so if i get the TF100 now, will it still be good next season?
    Jan 2012
    7,693
    Re: Clueless Newbie
    The reagents are guaranteed for 18 months, but I've used some longer than that without a problem.
    They also have always put full kit replacements on sale in spring for about $35.
    Sep 2016
    Clover, SC
    128
    Re: Clueless Newbie
    OK I got my kit and here are the test results... I hope ya'll can help me
    FC 5.5
    CC 1
    pH 8.2
    TA 660
    CH 75
    CYA 100
    What's next? looking forward to a crystal clear pool (fingers crossed)
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Re: Clueless Newbie
    Clover SC in the house, love it.
    You are going to need to SLAM, as YippeeSkippy said in post #2. Here's the bad news. You are going to need to replace at least half the water.
    I am curious, being very familiar with the area, why in the world is your water super expensive? It's dirt cheap in surrounding locales.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Sep 2016
    Clover, SC
    128
    Re: Clueless Newbie
    Hey neighbor! Oh removing half the water is going to be a problem! Is it worth it this close to the end of the season?? Can the pool be maintained in the winter so a SLAM is not necessary every year? Ugh so frustrated and confused.
    The pool was clear after adding 3.5 cups of low and slow for 4 days and adding 3 pks of shock 1st day and 1 the next. Is draining 1/2 the water an absolute necessity?
    The water is so expensive since we live outside of city limits and the water rate is double, it is supposedly run up from Gastonia or something like that. (some people in our neighborhood have had monthly bills over $200) Not sure what my bill will be as we just moved in 8/17 and have not yet received one yet. (biting nails)
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Re: Clueless Newbie
    If the CYA is actually 100, the minimum FC is 7, the target is 12 and SLAM level is 39 Pool School - Chlorine / CYA Chart I suspect it is higher. You could SLAM at that CYA, but to start it would be ~6 gallons of bleach and a lot more after that to keep it there. IF it is actually 100. Here is a Pool School article: Pool School - CYA
    Check out the "If your CYA level is 90 or higher" bit
    Jun 2016
    Panama City
    100
    Re: Clueless Newbie
    Do you get a decent amount of rain? Drain off 6" and use rainwater! Drain and repeat! You could lower it enough to make a slam a little easier. Be creative....setup a collection system....just thinking outside the box filled with water! But honestly...what if a drain and refill was 75 bucks? You will save that and more in one season by not going in a pool store and buying all the stuff they tell you that you need and you really don't! My pool is much smaller but I have yet to buy anything more than bleach and borax and a small jug of stabilizer.
    Aug 2014
    Northern IL
    4,615
    Re: Clueless Newbie
    The link Mr. Bruce gave you above is a good one. (http://www.troublefreepool.com/content/220-CYA). Look at step 9 and do that dilution test for CYA next time it is sunny. Let us know your results!
    Sep 2016
    Clover, SC
    128
    Re: Clueless Newbie
    no not really, normal amount...I think we are in a drought right now too. We were thinking to implement a rain barrel system down the road for pool topping and/or to maintain a veggie garden. I am hoping to get to the point that we only need the items you mentioned above to maintain. Fingers crossed
    Quote Originally Posted by JEC11718 View Post
    Quote Originally Posted by MarianParoo View Post
    When I did CYA test I did it inside, didn't realize I needed to do it outside with sunlight. let me do it again this afternoon the way #9 is saying and I will post results.
    Sep 2016
    Clover, SC
    128
    Re: Clueless Newbie
    This may be a stupid question, but can i do the CYA test when it i cloudy or do I need bright sunlight?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Re: Clueless Newbie
    It's best to do it in full daylight, back to the sun, holding the tube waist high with just 2 fingers at the top. I know it sounds crazy, but the point is to get as much ambient light to the tube as possible.
    Sep 2016
    Clover, SC
    128
    Re: Clueless Newbie
    OK testing CYA normally it was slightly under the 90 mark, then I did it like #9 on the link and it was 150.
    So I guess I have to empty 1/2 my pool?
    Last edited by Staci; 09-16-2016 at 04:30 PM. Reason: Edited tested again after reading that ALL traces of black dot need to not be visible (last reading I still saw it slightly)
    Aug 2014
    Northern IL
    4,615
    Re: Clueless Newbie
    If you want to fix it, yup. Hey, are those stairs removable? They look like an ideal breeding ground for algae and your slam will go a lot faster if you can clean the pool and the stairs separately.
    Please familiarize yourself with PoolMath. Here is a tutorial: Pool School - PoolMath
  20. Back To Top    #20
    Sep 2016
    Clover, SC
    128
    Re: Clueless Newbie
    Yes, they are removable and we will take them out to brush those nasty little greenies away!!
    Going to be a SLOW drain, we don't have any way but a garden hose to syphon out the water. Any recomendations on how to speed it up?
    Once we drain and refill how do I know my desired level? Is this chart (http://www.troublefreepool.com/conte...mmended-levels) what I go by?
