Thread: TF-100 Test Results
    Aug 2016
    Lumberton, TX
    14
    Question TF-100 Test Results
    Still struggling to get my pH down. It reads the highest the test goes every time (8.2). Any help would be appreciated. Just had a new Salt Cell installed about 3 days ago, so not sure if that has anything to do with it. Here are my latest results from this evening.
    pH=8.2
    FC=17.5
    CC=1
    TC=18.5
    CH=450
    TA=120
    CYA=80
    18k gal, IG gunite, saltwater, Hayward TurboCell, Hayward cartridge filter, spa w/water feature
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Re: TF-100 Test Results
    You need to use muriatic acid to lower ph and TA.
    Sent from my iPad using Tapatalk
    This will help you understand.
    Pool School - Lower Total Alkalinity
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
    Feb 2015
    Chandler AZ
    929
    With FC above 10, the pH test is unreliable. Let your FC drift down to 10 or less and check the pH again.
    What is your salt level?
    How does your water look?
    Why is your FC so high? were you SLAMming?
    With a SWCG, you might want to work on getting your TA down in the 60-ish range to help keep your pH a bit more stable. Of course, do this only after you've tweak all your other numbers.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Aug 2016
    Lumberton, TX
    14
    Salt level is at 3200 ppm. Have not slammed or anything like that. Salt cell is running at 85%. Water is crystal clear.
    How do I let my FC drift down?
    Jul 2014
    Hope Mills, NC
    567
    Turn the SWG down or even off.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Feb 2015
    Chandler AZ
    929
    Quote Originally Posted by Griswald View Post
    +1
    And test to see how much it drops - daily. Once it's 10 or below, test and adjust pH.
    Oh, how many hours per day is the pump running?
    Please add your pump make and model number to your signature (filter model number and SWCG model too).
    Gene
