Thread: First Numbers with TF-100
    irishal's Avatar
    May 2009
    Edmond, OK
    I got my TF-100 kit today and was so excited to test my first numbers (I've been using strips to this point). Below are my first numbers with the kit. My question revolves around my TA....200 is high I know, but my water is sparkling blue. Should I go ahead and put some MA in to lower my TA and PH and then aerate to bring back up my PH? Also is my CC being 0.5 ok?
    FC 6
    CC 0.5
    TC 6.5
    PH 7.8
    TA 200
    CYA 40
    Temp 88F
    30ft AG pool
    2HP pump
    the other parts I'll figure out tomorrow
    30ft AGP
    2hp pump
    TFTestkits ,Pool Calculator, Pool School
    Re: First Numbers with TF-100
    Your TA is a bit high. That will tend to cause the PH to rise, especially when it rains or there are kids playing in the pool. You need to keep an eye on things and make sure the PH doesn't get too high. It might be simpler to lower the TA now, though if you just lower the PH anytime it gets high that will have the same effect in the long run.
    Your FC is towards the high end of the range. If you just added chlorine, that is fine. If it is most of a day since you added chlorine, then you could let the FC level come down a little. FC between 3 and 7 is the normal range with a CYA of 40.
    Other than that, your numbers look good.
