Thread: Hayward AquaBug Question
    I'm thinking about investing in a pool cleaner for my above ground pool.
    Would the Hayward AquaBug be a good buy for $120 or should I spend more on a better unit?
    All I need it for is to pick up small debris that settles to the bottom.
    ultra800_96's Avatar
    May 2009
    Pomeroy, Iowa
    225
    Re: Hayward AquaBug Question
    I've had an Aquabug for 10+ years now & it works well for me. My pool is a 24 round with a flat bottom. My neighbors have also used it in their 15x30 oval flat bottom pool as well with good results.
    12,900 Gal. 24' X 48" ABG Vinyl Round (17th Birthday)
    1HP Hayward Pump w/S180T Hayward Sand Filter
    AquaTrol RJ SWCG 2011 startup
    TFP Method since '09, TF100
    50ppm Borates, June '12
    I'm using a 1 hp Hayward Pump. Would that be sufficient for powering the Aquabug?
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Yep, that should be fine. I ran my bug on a 1hp pump last year with no problems.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
